MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: BrickKollector on September 03, 2016, 03:55:35 AM
Title: WTB various K1004V or K1100RS/RT parts
Post by: BrickKollector on September 03, 2016, 03:55:35 AM
WTB K1004V or K1100RS/RT exhaust in very good condition. No scratches or dings but if it needs a good polish thats cool. Also, fuel and temperature gauges, and front brake M/C and lever. Has to be cosmetically perfect.
Prefer Aussie or NZ sellers sellers to avoid freight. Can collect Sydney or Melbourne
Title: Re: WTB various K1004V or K1100RS/RT parts
Post by: The Mighty Gryphon on September 03, 2016, 08:37:08 AM
I don't know if you are doing a concours restoration or if all you want is a functional exhaust, but the earlier K100 square muffler and header pipes can be fit to the 4V K100RS with a bit of fiddling to accommodate the different footpeg mounting plate.  My bike was cracking header pipes where they entered the collector.  No problem with the older exhaust.
If the Motronic has an oxygen sensor, you'll need to get the adjustment thingy that attaches to relay box that gives a replacement signal.  My bike had that already as the P.O. installed a Remus System after the third cracked pipe and the warranty had run out.
Post by: BrickKollector on September 03, 2016, 03:59:22 PM
Thanks Mighty, but the restoration is a '91 K1 so oem style exhaust it is. The system that came with the bike has a good scrape/dent in the muffler and the welds are very suspect with the #4 pipe falling off as I removed the header bolts...
Another alternative would be to use the K100 2V exhaust and graft the 4V muffler to it without the cat. Save some weight and improve the exhaust note can only be a good thing
