TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: TheEnginere on August 24, 2016, 08:35:38 PM
Title: K1100LT year 1993 Cafe Project, PLEASE HELP A ROOKIE OUT
Post by: TheEnginere on August 24, 2016, 08:35:38 PM
Hey there all K-series fans.
I just got myself a K1100LT.And my plan is to make it a cafe racer style.But my problems start with changing the handlebars to strap-ons.
Soo the question is:"Does someone know what size strap-ons to fit on my '93 K1100LT?"
More questions:
"Can i replace original wheels with,let's say K100 wheels?"
"Where the hell i can find controller switches to fit handlebar and still have choke button on them?"(not chinese sh*t)
Hope i dont bother you guy's too much. :)
Title: Re: K1100LT year 1993 Cafe Project, PLEASE HELP A ROOKIE OUT
Post by: Laitch on August 24, 2016, 11:08:00 PM
Welcome, Enginere
Post a picture of your bike in this thread so we can watch what you do to it, or what it does to you. Use your 1100 rims if they are in good condition.
Check out these two sources:
http://cafe4racer.eu/en/24-bmw-k75-100-1100
http://www.discovolantemoto.co.uk/handlebars-and-controls-58-c.asp
Post by: Revrdmark on August 25, 2016, 12:04:49 AM
More questions:
I used an '02 Kawasaki ZZR1200  control cluster for the clutch side that had a built in choke lever. I had to  shorten the cable and solder a new end on it but it works fine. you can look at my thread for the project  here : http://www.motobrick.com/index.php/topic,8675.msg68487.html#msg68487
Most people go to the K1100 tire from the K100 because the K1100 tire is fatter, rather than the other way around.
Post by: TrueAce on August 25, 2016, 01:10:56 AM
Well, couple of general points..........maybe you don't want to use 41mm clip-ones for all that LT weight, consider RS bars. Don't go to K100 rims because they are a more narrow width........many folks have gone to great effort to put 1100 forks on K100 bikes, you want the wider 1100 wheel, just over-size the rubber a bit front & back.Remember, the choke isn't anything but a throttle advance, it's not a carburetor being choked.And finally, have you delved into the Liebrary archives on each topic you've asked? Tremendous amount of " Been there, Done that", so go do your research. You ain't the first to grapple these weighty issues! POST PICTURES!
Post by: Scott_ on August 25, 2016, 07:01:25 AM
I'll just add that with the 1100 wheels, the stock RS rear rim is wider than the LT rear.
Stock Rim sizes LT:
front 2.5 x 18
rear 3.0 x 17
Stock Rim sizes RS:
front 3.5 x 17
rear 4.5 x 18
Post by: TheEnginere on August 25, 2016, 11:45:11 AM
Right now the bike looks like this
Post by: Revrdmark on August 25, 2016, 11:46:36 AM
Lol I'm sensing a theme here of keeping the 1100 wheels :-). If you do want to switch to K100 wheels there are a couple things to consider. The thinner k100 wheels limit you somewhat with choice of tires. ( not a huge deal most of us find a tire brand we like and stick with it). Also you will need to fabricate some spacers for the axel and brake calipers to compensate for width, or just run the wheel a little off center. I have seen several k100s that put 1100 rear wheel on and just used longer lug bolts and run them off center a little with not much problem. But the front would have to pick up that slack with a spacer on the axel and the calipers. It's not a huge problem but something to consider.  Some people like the thinner wheel look to get that more "retro" style. Personally I'd love to get wire spoke wheels made for my K100 but it would cost me more than I have spent on the total project.
Post by: Laitch on August 25, 2016, 12:13:19 PM
Did you buy it with that bobbed tail, Enginere, or did you attack it with a Sawzall after a fit of inspiration?
Post by: TheEnginere on August 25, 2016, 02:21:14 PM
I found it like this, soo now my plan is to save the bad boy ;)
Post by: Revrdmark on August 25, 2016, 02:39:05 PM
Wow they didn't leave you much room to work with on the tail did they!
Post by: TheEnginere on August 25, 2016, 02:51:17 PM
Yeah, it's a welding question :D
Post by: TheEnginere on April 11, 2017, 03:36:39 AM
Can someone help me to figure out what is this thing so that i can look for a new one ?
Post by: Scott_ on April 11, 2017, 07:45:01 AM
See if this helps you out.
http://www.motobrick.com/index.php/topic,536.0.html
