TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: frankenwing on August 11, 2016, 06:12:01 PM
Just bought this old k75 a couple weeks ago. Been restoring it inch-by-inch and I've come across a bunch of mystery things; wiring connectors that don't go anywhere, missing hose lines, etc.
I've checked the manual have searched over and over, but I can't find out exactly what this nipple is for, or where it should be routed. I'm guessing its just a vent, and thinking of putting a line on it to just run out underneath the bike.
(https://d3vv6lp55qjaqc.cloudfront.net/items/0c392k2X0H2r2A3V2x2X/nips.jpg)
Just cap it off. It used to vent the crankcase to the airbox (I think) but caused all sorts of starting problems. Mine's been capped since it's first service.
:2thumbup: Thanks!
Fuel tank vent...........US only.
As Chaos says, just blind it........it was a service bulletin about that......as you could get fuel into
the crankcase if overfilling the tank.
Weird, that one runs over to my throttles on my K100. Is this a normal difference, or possibly something the PO did?
Interesting. That explains the line coming from the gas tank. I was wondering if thats where it went since it fits, but i also thought it was odd to run overflow/vent to the case.
:2thumbup:
Speaking of nipples -- which everyone loves to do -- what's this? If fell on the ground while I was disconnecting something to lift the frame off the engine. Kinda looks like that other nipple except that one's sticking out of the engine.
A one way valve, is used inline on the above mentioned tank vent system.
Hang on to it. It will work as a one way valve for brake bleeding.
:2thumbup:
Part of the EPA rules only here in the states, same rules that required the CAT converter in the exhaust.
Your car/truck has the same thing(if it's new enough, and gas only), engine draws the 'vapors' from the fuel tank when running. Newer computer systems on todays cars/trucks even measure this vacuum and will give you a check engine light if it can't meet a specific threshold.(and some wonder why the CE light comes on when the don't get the gas cap tight..... :2thumbup:)
