TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: thor0864 on July 09, 2016, 03:56:59 PM
Doing a cafe racer out of my straight K100, and it seems a lot of guys are removing the bracket that holds the front fender, then fitting an aftermarket fender in the more standard way using the 2 Bolt holes on either side. Until I saw others doing this, I had assumed that that bracket had a structural purpose as well, strengthening fork rigidity. Now I'm pretty sure that it's nonessential. Can somebody confirm this? Thanks, Stein
if you have the one piece finder you're fine. The later 2 piece fender has an aluminum fork brace between the front and back fender halves and is pretty essential.
Thanks for the quick reply! Yes I should have clarified that I do have the two piece fender unfortunately. Sorry to hear you think it's structural, since it's so damn ugly when the stock fender is removed. May opt to replace with a custom piece that's less unsightly. No idea why other bikes are fine with the fork braced at two fixed points (axle and top), whereas you're saying I need a third brace point, seems excessive. Anyway I'll likely follow your advice, thanks again, S.
