TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Brahma on July 01, 2016, 06:11:10 PM
Title: Electrical Gremlins- no horn?
Post by: Brahma on July 01, 2016, 06:11:10 PM
Hi all!
In 31 years of ownership, my early K100RT has thrown me my first puzzler- no horn.
* Starts and runs fine, everything operable but no sound from either horn.
* Sound comes from the relay when operating the horn button.
* Pulled the tank, open the electrical box, swapped the relay out- same symptom.
* Pulled the connection to the horns/parking light/turn indicators, measured the voltage when the horn button is depressed, and 13+ v measured
* Reconnected, measured voltage at horn with ZERO v measured.
* Applied battery power directly to horns- they work!
* I checked continuity of each wire and get weird results, like there is a short or broken wire.
* I checked the Max BMW fiche and my early RT harness is not available- it looks like BMW separated the indicators from the horns, leaving my main harness one connector short.
Recommendations from inmates appreciated...
Title: Re: Electrical Gremlins- no horn?
Post by: Elipten on July 01, 2016, 06:49:49 PM
Sounds like you have your answer.  The BMW undersized wires are shot.  Just run new wires along the harness and eliminate the original factory wiring.
Post by: rbm on July 01, 2016, 06:53:14 PM
Sounds like a failed connector.  Two possible locations - the relay socket itself or the connector in the harness.  Remove the relay socket from its perch in the relay box and make a voltage measurement on the Green/Grey wire (the fact you hear the relay means Green/Red power and control cabling are probably OK).  Press the horn button and you should read 12V.
Locate the 5-pin connector for the horn, parking light & turn signals under the tank.  Clean it and test voltages at that point with the Green/Grey wire. Test both sides of the connector to isolate the problem.  Are you also experiencing any turn signal or parking light problems? That might also point to the same connector.
As for wire size, they are standard 1.5mm2 which should be OK for the current drawn by the horns.
Post by: Brahma on July 01, 2016, 09:23:17 PM
Thanks for replying!
12 v is getting to the 5 pin connector of the harness to where the outer harness that leads to the horns, parking light and turn indicators.
I plug in that outer part of the harness, and 12v is getting to the horn leads.
I plug in the horn leads, and measure there with the horn button on, and it's only .25v!  WTF?  But, the parking light comes on, and the turn lights work!
I checked for continuity and all wires are good.  I tried to check resistance (don't quite know what I'm seeing) and the meter comes up 000.0 on all, which I think is good.
The system has a load-shedding relay to kill power sources while the starter button is pressed, but I'm not doing that.  The horn always was live when the key is on.
Where did my other 11.75 volts go as measured at the horn?  Bad switch that can't handle the load?  I swapped relays and same results....
Post by: kioolt on July 01, 2016, 09:48:26 PM
You should leave your horns plugged in for all of the measurements that you are taking so that you are loading the circuit.  Do not unplug anything.  Stick you meter lead into the back of the plugs to take your measurements.  You should be able to find out where the voltage is dropping by doing this.
Post by: Brahma on July 01, 2016, 11:22:43 PM
Well, I took data points in all configurations, and the bottom line is there is .25v measured at the horn when plugged in at the horn, which I do not understand, when there is 12v before plugging the horn in.  I did test the horn with 12 v straight to it which it worked fine.
Something isn't taking the load.  I will order another relay first, because it's cheapest, the only thing left is the switch, but I would think if it triggers the relay, that is all that is needed.
Post by: kioolt on July 01, 2016, 11:35:04 PM
You should leave your horn plugged in.  Let's say that point A is the relay, point B is the next connection, point C is the one after that and so on.  If you've got 12v at point A and not point B, then your problem is between the two points.  If you've got 12v at point B and not point C, then your problem is between point B and point C.
I don't believe you ever said what the voltage is at the relay with the horn plugged in.  What is it?
Post by: Laitch on July 02, 2016, 12:08:35 AM
Why wouldn't the horn button contact within the multi-switch be considered the culprit? I realize that's easy for me to ask because almost every other possibility except the effects of heavy gravity has been listed.
Post by: Chaos on July 02, 2016, 12:36:25 AM
don't have the schematic handy but another bike I had the horn button completed the ground circuit, the positive side was unswitched.  Confusing until I figured it out
Post by: Inge K. on July 02, 2016, 04:50:22 AM
First you can test by swapping the horn relay and load shedding relay, as those is identical.
Post by: Brahma on July 02, 2016, 05:32:59 AM
I swapped the relays, and the same symptoms exist.
How do I measure at the relay- take it apart?
I measured with one horn being plugged in, not both. .25 v at that horn.
The parking and turn lights work fine.
Post by: kennybobby on July 02, 2016, 06:55:18 AM
When you had the tank up did you inspect/clean the ground collection point at the frame bolt?
There appears to be another ground collection point near the horn harness connector pin 5 also--maybe inspect for corrosion.
It seems that you are getting voltage to the horn when unloaded, but the return path back to the battery is blocked.
Where are you placing the negative test lead of the meter when measuring 0.25?
Post by: Brahma on July 02, 2016, 08:40:30 AM
I have the negative test lead at a bolt on the frame.
The parking light and turn lights share a common ground in the sub harness, and they work.
Do I need to have both horns hooked up?  I wouldn't think so....
The problem kind of points to the sub harness connector for the horns (both power leads come from one pin), but what I don't understand is that both read 12v when not connected to the horns, and .25 v when one horn is connected.  Am I missing something by not testing with both horns connected?  I ask, because I am at the beach right now.  :)
Post by: kennybobby on July 02, 2016, 09:44:55 AM
Pull fuse #7 and make sure it is good, then does your radiator fan turn freely by hand or is it locked up or stiff to turn?
The power for the horn is on the same circuit as powers the fan, and powers the flasher unit--disconnect the temperature switching relay unit under the tank and try the horn again.  Disconnect the flasher unit and try the horn again.
That's all i can see that could remotely affect the #7 fuse 12v line that becomes hot when the key is turned to the ON position, aka circuit 15.
Post by: Brahma on July 02, 2016, 03:00:16 PM
The fan turns freely.
Fuse #7 is fine.
I tested with both horns connected- no change.
Again, I measured 12v at both sets of horn leads NOT plugged into the horns
I then plug the horns on, and measure .25 volts when the horn button is pressed.
WTF is going on?  I'm getting "perturbed".
Post by: kioolt on July 02, 2016, 03:18:19 PM
You still haven't said what the voltage is with the horns connected at all of the other points in the horn circuit that you have checked.  This WILL tell you what connection is causing the voltage drop.
Post by: kennybobby on July 02, 2016, 03:29:46 PM
i just went out and checked by horn.
i disconnected the horn and measured 12v at the green/gray wire when the key was ON, kill switch at RUN, and the horn button pressed.
i measured the resistance of the horn at less than 5 Ohms.
With the horn once again connected i measured 0.25 V when the button was pressed, and the horn was sounding.
i measured the horn current at about 4.5 Amps with the button pressed and horn sounding loudly.
It seems that you are getting the voltage drop across the horn but not enough current flow to make it toot--definitely a gremlin of some sort...
Post by: Brahma on July 02, 2016, 03:56:25 PM
Thank you- I guess .25 v is normal then (?)
The lights share the same ground of the harness, so I really don't know.
Post by: Brahma on July 02, 2016, 03:57:38 PM
No wonder the sub-harness design was changed...
Post by: Brahma on July 02, 2016, 04:07:17 PM
I was reading your reply while you were making edits and I agree, weak current would have to be the relay.
I kept an old one and will try to resurrect it...  I will order one this week.
THANK YOU!
Post by: kennybobby on July 02, 2016, 04:08:46 PM
Fuse 7 and the horn relay are powered thru the load shed relay, so swapping the horn and load shedder doesn't rule out bad relay contacts as the root cause--the horn current has to travel thru both relay's contacts.  You can disassemble the relays to inspect the contacts, but i'll put $ on a bad relay as the culprit.
The return path for the load shed relay is thru the starter motor brushes, which is johnny's electrical whack number 1.  i don't believe in trying to back-drive the starter with the jenner thru the engine, but it may be that the carbon dust in the starter motor needs to be cleaned out to make a good ground path for the load shed relay.  A flaky ground lets the contacts bounce and then they arc and get frosty and high resistance junction, etc...
Post by: Brahma on July 03, 2016, 03:06:40 PM
So, today I bought some decent clip leads and performed a test of the relay.  I powered up poles 85 and 86 with a fully charged motorcycle battery, heard the contacts close, then performed a continuity test across poles 87 and 30.  Test was positive for continuity.
I then moved over to the bike and connected poles 87 and 30 to one horn, then powered up the relay.
Nada.
Puzzled, I read the voltage between poles 87 and 30, and it was non-existent!
How can a relay have continuity powered up, but have little or no voltage coming out of it?
Bad coil?
Post by: kioolt on July 03, 2016, 03:22:24 PM
Nada.
Pole 30 should be connected to the battery or hot fuse, not the horn.  Pole 87 should be connected to the horn.
If you put one lead of your meter on pole 87 and the other on pole 30, zero would be the correct voltage.  You should have 12v on pole 30 to ground even before you press the horn button.  Pole 87 should have 12v to ground while pressing the horn button.
Post by: Brahma on July 03, 2016, 03:37:49 PM
So I tested it backwards?  I should put the 12v on 30, ground on 87, then read voltage from 85 and 86?
Post by: kioolt on July 03, 2016, 03:52:03 PM
Do not put 12v on 30 and ground on 87.  That IS NOT what I said.  I said you should measure the voltage on pin 87 to ground.  That means put one meter lead on pin 87 and the other meter lead to ground.
I'm assuming you are trying to test the relay out of the bike for the following instruction.
Put 12v + to pin 30 and 86.  Put ground to pin 85 and one side of the horn.  Connect the other side of the horn to pin 87.  The horn should blow.
Post by: Brahma on July 03, 2016, 04:19:37 PM
"Put 12v + to pin 30 and 86.  Put ground to pin 85 and one side of the horn.  Connect the other side of the horn to pin 87.  The horn should blow."
The horn blows in this configuration.
I have dissected the sub-harness that goes to horns, to look at the ground juncture and it is solid.  I have tested each pair of horn leads with a turn indicator bulb connected through a motorcycle battery, and each pair lights.
So what the "F" is wrong with my bike?
Post by: kioolt on July 03, 2016, 04:30:02 PM
When installed in the bike do you have 12v from pin 85 to pin 86 with the horn button pressed?  You should be able to hear the horn relay click.
If yes.  Do you have 12v from pin 30 to ground with or without the horn button pressed?
If yes.  Do you have 12v from pin 87 to ground only with the horn button pressed?
If yes to all of the above you have shown that your horn button, horn button wiring, and horn relay are working properly.
If no to any of the above, please get back with details.
When I use the term from to I mean to put one meter lead on the from and the other meter lead on the to in my instructions.
Post by: kioolt on July 03, 2016, 04:32:15 PM
Make all of the about tests with the horn hooked up and the horn relay plugged in.
Post by: Brahma on July 03, 2016, 06:26:32 PM
Issue is fixed.
The diagram I was referring to was WRONG- I was troubleshooting the wrong relay.
Luckily I had a spare that I thought was bad, that was used in the testing, but apparently it is good.  I left the newer one in the middle alone, then swapped my used one for the outermost relay which is THE HORN/FAN relay.
HONK! HONK!
No wonder the mysteries.
Thank you ALL.
Post by: Sanfrid on May 21, 2021, 03:57:12 PM
Hi,
Looks like I'm having a similar problem with my LT -94.
Tried what you recommended - Kioolt - and looks like i don't have any 12v from pin 87 to ground with the horn button pressed.
Do you have a any idea on how i could potentially fix this!
Thankyou in advance!
Post by: rbm on May 21, 2021, 04:28:31 PM
- Check for voltage at pin 30 with ignition on.  If not there, then check fuse 7 and replace if burnt out.
- Check that pin 85 has 12V without the horn button being pressed and about 0V when horn button is pressed (with ignition on).
If pin 85 doesn't go to ground potential, then check the left hand controls connector for proper connections.  Clean the contacts with cleaner like Deoxit.
- Check ground connections to frame for both the horns and horn button.  Clean with a contact cleaner.
If after all this, no problem is found, the replace the relay.
Post by: Sanfrid on May 22, 2021, 07:05:15 AM
Hi rbm,
thank you for such a fast response!
1. I have voltage at pin 0 with ignition on.
2. I also get the "click" when pressing the horn and the fuse is installed.
3. But i do not get 12V's at pin 85 without the horn button being pressed. I have nothing on pin 85 no matter if the horn is pressed or not.
I checked the left hand control connector and all looks well, also added some Deoxit for good measure.
I have to say that im not 100% sure where to find the ground connector for the horn and the horn button, any chance you could give me a hint?
thank you in advance!!
Post by: rbm on May 22, 2021, 07:49:54 AM
Your description makes it sound like the horn relay is bad.  Try swapping the horn relay with the fan relay and see if the problem moves with the relay.  Check out this page to help you identify the relays if you don't know the relay box layout: http://www.motobrick.com/index.php?topic=536.0  Yours should match the diagram for ABS I bikes in the second post.
Post by: Sanfrid on May 22, 2021, 08:04:44 AM
Hi,
Have tried that and the relay is fine.
I tried to connect the horn's ground directly to the ground point under the tank and the horn works, so feels like the issue should be with the ground that is connected to the horn. Do you know what ground point this is?
Looked in my Clymer and online and have not had any luck in finding out yet.
Post by: beemuker on May 22, 2021, 08:06:06 AM
This youtube that Laitch posted on my issues thread helped me understand relays.
https://www.youtube.com/watch?v=IpRWcNoLdwQ&t=3s
Post by: Sanfrid on May 22, 2021, 08:08:42 AM
Thank man, this video is great, already watched it actually when trying to figure this out :)
But i think the issue is with the ground as all works when i run a "new ground" and connect it to the ground point under the tank.
Does anyone know what ground the original horn cable is connected to?
Post by: beemuker on May 22, 2021, 08:25:28 AM
My issue turned out to be the 4 pin tank connector, had power going in, none coming out. spliced a trailer connector in and the pump works. Hope you issue is as easily resolved.
Post by: Laitch on May 22, 2021, 08:40:28 AM
Have you removed all the wires from that ground point then cleaned and inspected all their terminals and the attachment point itself?
Post by: Sanfrid on May 22, 2021, 09:15:57 AM
Hey,
I fixed it by just making a new ground and connecting it to the connector under the tank.
Works like a charm now. Thankyou all for the quick answers, been really helpful!
Hope you have a great day!
Cheers ,
