TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jay1622 on June 28, 2016, 09:07:40 AM
Title: Protective bushings between tank wall & the pump housing?
Post by: jay1622 on June 28, 2016, 09:07:40 AM
Searching for what these are using my bikes VIN and also the engine codes of a few later models. I tried searching terms like... cut hose, damper, buffer block, rubber bushing and all sorts of other stuff and have yet to find anything. Mine were so rotted, I'm guessing I mistook them for partially disintegrated fuel hoses. No bulletins either. Protective purposes I'm sure, but no mention or part numbers. Is this just an add-on? I've seen them quite a few times while searching other pump related stuff.
Title: Re: Protective bushings between tank wall & the pump housing?
Post by: Laitch on June 28, 2016, 12:21:50 PM
Undoubtedly, reading along in this K100 forum thread (http://www.k100-forum.com/t4467-k1100-fuel-pump#46556) will help make everything clear, jay. :giggles
Post by: Elipten on June 28, 2016, 06:53:49 PM
Mine were shot so I used some fuel line designed to be submerged in gasoline
