TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: Devil K on June 16, 2016, 01:46:10 AM
This thread will be dedicated to turning my 1994 BMW K75S into a cafe bike... more or less at least.
When I first got this bike I knew that the transmission was bad. During repairs i soon found out that the drivshaft was bad as well. Since then i have given the whole rear end of the bike a complete overhaul. New used 5 speed transmission, custom driveshaft, the previous owner installed a new used final drive (I wonder if I can find another final drive with taller gears?). Shortly afterwards though I snapped my clutch cable. I have found another one on ebay, just waiting for funds to order it.
Here are some photos from the overhaul
More photos of the tranny and shaft replacement.
So on my quest to build my dream bike This little bastard decided to snap on me
Aha!!! I got so excited it fired up on the first try. All of that hard work finally paid off.
[attachment[/attachment]
That does not look like a K75S. Looks like a base model/75C.
What is the VIN?
I don't have it on me, I'll check when I get home.
What is the VIN?
It's a hybrid.
Rear brake would be a drum,the final drive ratio will by lower ratio too.Forks are the next distinction.
Dressed as a C.
94 S model vin's start with 0154xxx
i don't see any S bike parts on yours.
A stock K75 wouldn't have bar weights either. It's hybridized, like Dude said. A C would have a slightly differing headlight assembly, too. It looks to me like a Standard that got a C-bar. It's the perfect candidate for cosmetic surgery. Pretty good pics, Devil.
What's body type model:rs
Reisesport
Where'd you get that abbreviation?
So it has a c bar, does that mean that it's a mid/high rise handlebars? The first digits of the vin are 1057
Don't be coy. Answer my question, Devil.
I'm the non-op
I'm the non-op
10-4
On the nonop. But if this is a hybrid then the fucker I bought it from lied to me...I just bought a clutch cable for low rise handle bars too.
I thought for sure the rear disc brake was a give away
Not to mention it has a 17 in the rear. It's deffinetly not stock but I'm 99 percent sure that it's an S.
It's a beautiful evening. I think I hear barred owls hooting in the distance.
Wrong first digits. The VIN usually refers to the last 7 digits in that long series. The first part is other codes saying where it was made and other info. When I said first four it was the first four of that 7. What are the last 7 digits of your vin?
VIN Last 7 digits should be 0154xxx. Mine was the first 94 S made. Vin 0154291. Yours would be higher than 291.
You can also put your last 7 into realoem.com and it will tell you what it is.
Yep, those are barred owls all right.
I think that you guys are right. It's a standard
0134935 are the last seven digits.
So then let me ask you guys this. If I ordered a low rise clutch cable will it still fit these C handlebars? Really wish someone hadn't already had at my bike, now it's even harder to find parts for it.
At maxbmw there's a cable labeled "low/medium applications." If that is the one you bought and you do have a C-bar, let not your heart be troubled and avoid wasting valuable cursing time by wishing for the impossible.
Actually, since we have confirmed your do not have an S model, looks like you have a stock base model. No mods. Easy to look up parts for now.
