TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Dermy on June 14, 2016, 03:43:03 AM
Title: Leak underneath LT
Post by: Dermy on June 14, 2016, 03:43:03 AM
Hi guys
Had a tiny leak.
Then I started to move the rubber seal now I have a proper leak.
Where is this coming from and what do I need to fix it.
Is it safe to ride or will it do more damage.
Thanks guys
Title: Re: Leak underneath LT
Post by: K1300S on June 14, 2016, 06:17:57 AM
Clutch push rod seal.   If it is not torn,  it is at least unseated from the arm at the small end.
Post by: Scott_ on June 14, 2016, 06:57:08 AM
(http://www.maxbmwmotorcycles.com/fiche/Diagrams/B0000510.png)
Item #6, clutch boot, about $42.
Like was mentioned, if it is not torn, you should be able to re-seat it. If not then a new one is in order.
There is supposed to be some gear box lube within the boot to lubricate the push-rod "piston" aka throw-out bearing....
Would it hurt to ride? Not really but that's your call. It's only going to drip oil into the path of your rear tire.......
Post by: Laitch on June 14, 2016, 07:12:58 AM
Replace the boot as Scott_ and Marshall have indicated. You could try to attach a small can under the weep hole to catch the dripping oil for resale as a mosquito control in Belfast but the licensing of your recycling business would probably be more trouble than just the repair. It's good to see, though, that you're not letting sentiment get in the way of reusing materials. Our planet thanks you!
Post by: Dermy on June 14, 2016, 07:41:58 AM
Thanks chief
Mosquitos! In Belfast lol.
It's the women that bite ye in Belfast not the bugs
Post by: kennybobby on June 14, 2016, 08:32:58 AM
It looks to me like the coolant tank has sprung a leak a the bottom of the overflow tube (cracked at the clamp) and coolant has run down the gear position wire onto the clutch seal, where is it now dripping off.  kb
Post by: Dermy on June 14, 2016, 01:59:49 PM
Hi
Definitely not the coolant.
Rubber seal is leaking oil.
I've ordered new parts.
Just need advice on how to change it.
I'm a complete novice on mechanics
Thanks
Post by: Laitch on June 14, 2016, 08:38:57 PM
Pick up a Clymer manual then pour yourself a couple of drams and watch this 5/6 part video. It will explain removing the clutch cable from its lever, adjusting the sidestand lever, installing the boot and a number of other important maintenance items. You won't need to strip your bike down to the extent shown in this video but it's an education in various procedures and may help clarify instructions in the manual. If nothing else it'll be entertaining.
https://www.youtube.com/watch?v=HZJdZ1HszkA
Post by: Dermy on June 15, 2016, 01:44:44 AM
Feck me
There's a lot of feckin cursing going on in this video
It would drive you to drink
The Guinness is brewing as we speak  :riding:
Thanks
