TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Devil K on June 10, 2016, 05:08:54 PM
Do you guys think it's possible to transplant a k100 motor into a k75 and if so is there a difference in their transmissions, drive shaft, and final drives?
Front down tubes are different, probably cheaper to buy a K100 and sell the K75. Transmission drive shaft and final drive ( different ratio ) will fit.
Nor will the 4cyl fit under the S bodywork....
Marshall about 12 years ago there was a guy in the BMWMCQ who did fit K75s fairing to a K100 minus the belly pan. I have looked for pictures on their website but have been unable to find them.
That is only part of the package. No complete S fairing. ...it doesn't count!
Does so, some K75s did not come with a belly pan, it was originally optional, so there. Nana nana nah nah. :neener:
Regards Martin
Marshall just for you I finally found a picture of the K100s and it had a belly pan.
K100 belly pan... :bmwsmile like on my avatar
So my question is, is there anyone out there who could give me advice on the motor swap. And you are saying that it is possible?
greetings devil k...
it is possible with the right shop equipment... plasma cutter... tig welder... tube bender... frame table and so forth...
+1 Johnny but anything is possible, but it will require modifying the frame, a procedure that should be done by experienced persons.
Martin.
I think that the K75RT frame is a K100 frame. The radiator shroud from a K100 bolts on to a stripped RT. I understood that the K75 RT was built on the K100 frame to save reengineering the K75RT.
I d[size=78%]on't have a reference for this, only my experience with my stripped RT :2thumbup: [/size]
I bet a 3 cylinder turbo diesel from a smart car would fit.
bmwrn definitely different front down tubes between a K75 and a K100.
As mentioned a few times now, the downtubes are different as the k75 lump is one pot short but you are welcome to prove us wrong. You are right on the k75rt running a k100 rad but that has been done to prevent it from overheating when touring fully loaded 2 up in a hot environment... Bit overkill if you ask me...
Verstuurd vanaf mijn HUAWEI CUN-L21 met Tapatalk
