TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: beemuker on June 06, 2016, 04:37:07 PM
Title: rivets gone on bag latch, fix?
Post by: beemuker on June 06, 2016, 04:37:07 PM
Hi, when I removed my bags I noticed that 2 of the 3 rivets holding the latch that secured the bag to the bike are gone. the 2 that are gone are the ones behind the mechanism so to re rivet you would have to get that part out of the way. I don't see any way to remove it, what is the fix for this?
thanks in advance.
answered my own question, just put the rivets in from the bag side, duh!
Title: Re: rivets gone on bag latch, fix?
Post by: Chaos on June 06, 2016, 06:39:18 PM
at some point Lowes and HomeDepot start looking like good for replacement parts  :yes
Post by: Laitch on June 06, 2016, 07:27:45 PM
Abraham Maslow would be pleased.  :2thumbup:
Post by: mw074 on June 08, 2016, 03:32:55 PM
The saddlebags can be shimmed by gluing pieces of rubber to the bag where the bag contacts the mounting bracket. This keeps them from bouncing and also quiets them down. Helps to keep the latch rivets intact. Also do not strap to the bags so that they are lifted up (ie Bungee Buddies.) The saddlebags are designed to hang fully down. The surest way to pull out the latch rivets and bounce the saddlebag down the road is to strap them up. Also, make a small plate for the inside when you re-rivet the latch on. This helps to distribute the weight on the latch more evenly.
Post by: beemuker on June 08, 2016, 06:50:24 PM
thanks for the good advice
