TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Donmystic1 on June 03, 2016, 10:09:38 AM
On my 1991 K 1 left side knee pad there are three switches.
Hazard and ABS. The third is a blank
What is the function of the ABS switch?
I would think that ABS brakes would be on all the time.
Don
I did a quick search, using the search button, and found out it's for resetting the ABS system.
So it would normally be in the off position ?
there should not be an "on" position. should be spring loaded and only function is to temporarily kill the abs warning light if there is a malfunction.
Mine seems to be a rocker switch.
Down the light on the switch comes on. Up it goes off
It does not appear to be spring loaded.
Hmmm. Maybe k1 actually allowed you to turn of the abs?
Or the spring has sprung.....
