TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: burntstick on May 22, 2016, 11:38:45 PM
wanted power for gps /cell phone. but the bmw type cig. iighter plug in blew the fuse on gps and burnt up 2 usb plug ins. riding a 91 k75 lt . ideas for electrically challenged ?
Wired bassackwards?
The make and model of the GPS? The size of its fuse? Does the GPS work in a car? Does the socket charge the cell phone with no problem?
I had this one installed on my K100LT when I bought it but i've since then taken it off. Is this what you mean you're wanting to do?
my female power plug in is located directly off the alternator behind engine. was used previously to power a vest i think.needed a male female convertor to be able to use cig lighter type plug in
Where you've described is a non-standard location for the auxillary plug, so maybe the PO wired it backwards. A vest wouldn't care about polarity, but your USB devices do care. Make sure the centre pin is positive and the outer ring negative (ground).
thanks robert
