TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: rainman on May 22, 2016, 08:27:00 PM
Title: Grip size
Post by: rainman on May 22, 2016, 08:27:00 PM
Here's a dumb (or ignorant) question- I have a 1989 K100RS, with factory heated grips. The heat works fine, it's just that the covers are torn up and slipping off. What size grips should I look for to replace them? Thanks!
Title: Re: Grip size
Post by: TimTyler on May 22, 2016, 08:37:37 PM
This question has already been answered: http://www.motobrick.com/index.php?topic=6806.0
Post by: Laitch on May 22, 2016, 08:43:24 PM
You can answer it specifically by going to the Technical Library card catalog (http://www.motobrick.com/index.php/topic,666.0.html), scrolling down to Motobrick Modifications, clicking on K Bike Grips, then clicking on the pdf link.
Post by: johnny on May 22, 2016, 09:24:14 PM
greetings rainman...
welcome to motobrick.com...
i thinks what they are trying to say is next time you post up about what fits my motobrick perhaps you oughtta do your doo dillergence prior to making the post...
something like... i searched motobrick.com and found that folks here use the progrip 699 open end for heated grips... and i see an amazon link for only $8 bucks a set...
before i proceed i thought i would ask if you folks if you think i will tear up my grip heaters when changing grips...
i took the time to look up the oem part numbers... i see they are expensive... do you think i should go with kimpex or oxford or simpco or another aftermarket set like many here have already done...
rainman
greetings moetoebrickers...
if you want to know what parts fits your moto...
1st... getts the last 7 digits of your vin and put in here (http://www.realoem.com/bmw/enUS/select) to see what your moto really is...
2nd... then pick your moto here (http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx)...
3rd... after you figger out the exact part number put it in here (http://www.realoem.com/bmw/enUS/select) to see what all motos it fits...
4th... then put your questions in here (http://www.motobrick.com/index.php?action=search) and  search it...
5th... make your post... include the part numbers you looked up... include screen prints to demonstrate you doing the minimum...
when you do the minimum your post will stand on its merits... if you choose to not do the minimum... mystic red will have your post locked and pinned up on the wall of shame... and you will  be sanctioned for a time... plenty enough time to figger out how to getts part numbers and screen shots in your next post...
