TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: BAMBAM1039 on May 20, 2016, 03:43:31 PM
Im hoping someone can answer these questions On my 1990 k1 there are 3 switches on left side of tank in fairing One says ABS one is a triangle that looks like the red triangle on center of gauges and one is blank? Also what does lighted triangle on center of gauges do or stand for Thanks ahead of time for any helpful info
greetings bambam...
the abs button is for resetting your abs...
the red triangle is 4 way flashers...
the blank is heated grips... supercharger... or nothing...
the red triangle is the bulb monitoring unit...
now go use the search box to see what the bmu does... dozens of posts here about it...
if you want to post about anything elrctrical or mechanical or technical... you must first use the search button to acquire information (http://www.motobrick.com/index.php?action=search)... your post must demonstrate that you used the search button...
if you want to know what parts fits your moto...
1st... getts the last 7 digits of your vin and put in here (http://www.realoem.com/bmw/enUS/select) to see what your moto really is...
2nd... then pick your moto here (http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx)...
3rd... after you figger out the exact part number put it in here (http://www.realoem.com/bmw/enUS/select) to see what all motos it fits...
4th... then put your questions in here (http://www.motobrick.com/index.php?action=search) and search it...
5th... make your post... include the part numbers you looked up... include screen prints to demonstrate you doing the minimum...
when you do the minimum your post will stand on its merits... if you choose to not do the minimum your post will be locked and pinned up on the wall of shame...
thanks i guess flashers dont work and why would i reset abs and what is bmu?????? thanks again the triangle on dash goes out sometimes and stays on other times/
if your abs goes whack... and if you want it to work again it must be reset... does this moto have abs...
its all right here... including bulb monitiring unit info...
I soon learnt to push both indicator(flasher)paddle switches together to get all four going.Very usefull,as a silent horn!
Yeh,you probably knew that.Oh well.
