TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jay1622 on May 17, 2016, 09:54:02 AM
Title: Center Stand Failure Prevention Question
Post by: jay1622 on May 17, 2016, 09:54:02 AM
I read somewhere, here perhaps, to spray/treat/coat the inner steel pipe of the center stand with something to stop interior rusting, which would lead to failure. Same thing for the kickstand extension. Any thoughts? I'm finished with the exterior of mine and want to hit the interior with something before I re-cap it.
Title: Re: Center Stand Failure Prevention Question
Post by: Laitch on May 17, 2016, 10:02:50 AM
Paint like Rustoleum suitable for metal surfaces and periodic inspection with an endoscopic camera attached to a high-defintion monitor that has a 36" screen.
Post by: jay1622 on May 17, 2016, 10:08:51 AM
Kinda detailed there... Starting to think you're poking fun... I like where you're head is at... This thing's gonna rock, or, so I hope.
Post by: jakgieger on May 17, 2016, 02:17:52 PM
Jay, I think the natives are getting restless :hehehe.  It seems it was suggested here somewhere to use expanding foam to fill the pipes.  I've searched and been unable to find the reference :dunno2:...anyway, I have used foam but do not have long term results.
Post by: Martin on May 17, 2016, 04:25:06 PM
I cleaned mine out then poured in LPS 3 and let it soak the poured it out and let it dry then repeated the process. Esso used LPS products on the oil platforms in Bass Strait, a very harsh environment. LPS 3 leaves a waxy coating that will last  for years.
Post by: mw074 on May 17, 2016, 04:33:21 PM
Whatever the method that you choose to use, I definitely suggest using something. I was one of the unfortunate ones that had one break. Not pretty.
Post by: Mongrel on May 20, 2016, 01:49:53 PM
You fellas reminded me that I never got around to filling mine with expanding foam as I'd planned to... dangit. Already had one go on me and I'm on my second... so far.
Post by: The Dude on May 20, 2016, 02:28:32 PM
This is the method I have been using:
Bead blast all the shit off,weld any cracks&missing bits back on,Wire brush the shit off,hot zinc metal spray,powdercoat.
All my precious bikes are treated this way.Brick was done early '90s.
Good as new,still.
Post by: jjs1234 on May 27, 2016, 12:47:53 PM
You can use an updated k1200 stand. The mounting plate does not match up but the center-stand part eyelits do.
I will be using this fairly soon. They are also REALLY CHEAP ON EBAY!
Info:
http://www.k100-forum.com/t9623-k1200-centre-stand-for-k100
4th post
