MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: BenM on May 10, 2016, 01:26:58 PM
1993 K75RT w/ 93XXX Miles. $2000.
Located in Hamden, CT 06517. The reason I'm selling is that I just don't really, really like it. It does everything well enough, but think I need something else. I still ride it once a week to get it out and about. The only trades I'd consider right now would be for a 98-01 VFR800, or a 90's sports tourer.
Let's start with the negatives:
- Needs a rear shock
- Crack in the right side of the fairing
- Crash bars have surface rust from sitting outside
- Windshield is cloudy/scratched
- Left hardcase has small hole in the bottom (right above hot exhaust)
- Right glovebox cover flew off the other day on the highway
- Seat Latch broken (won't lock)
Besides the above, the bike is bulletproof and everything works on. It sat dormant for years before I acquired it last year and basically serviced/replaced everything that it needed, minus the above items. The bike has a few nice pieces including an H1 HID projector conversion that works excellent, Electric Windshield, Russell Day Long Seat & recently installed heated grips. When I'm not riding it, it sits on a tender in the garage.
Below is a list of maintenance done during my ownership with dates & mileage.
Flush Fuel Sludge w/ Kerosene & Carb Cleaner 91605
6/7/2015
Replaced Throttle Body Vaccum Nipple Caps 91605
6/10/2015
Replaced Crankcase Breather Hose 91605
6/10/2015
Installed New Battery 91605
6/10/2015
Installed New Spark Plugs 91605
6/10/2015
Removed Air Filter & Lower Airbox, cleaned out giant mouse nest 91605
6/11/2015
Installed New Air Filter 91605
6/11/2015
Installed New Fuel Filter 91605
7/22/2015
Installed New Fuel Pump Vibration Dampener & Strainer 91605
8/2/2015
Pulled Fuel Injector & AFM Connectors, Cleaned w/ scotchbrite & contact cleaner 91605
8/5/2015
Spliced in new wire for Yellow/Blue Connector on TGPI 91605
8/8/2015
Pulled Driveshaft, lubed 91605
8/12/2015
Changed Final Drive Fluid 91605
8/17/2015
Changed Transmission Fluid 91605
8/17/2015
Fix Left Side Hardbag Case w/ new metal hinges riveted to plastic 92000
11/22/2015
Oil/Filter Change 92000
11/22/2015
Installed New Fork Seals, Bushings, Progressive Fork Springs & Fork Oil 92000
11/24/2015
Removed Electric Windshield Motor, Cleaned & Greased, Re-Installed 92000
11/27/2015
Cleaned Hazard Switch contacts, needs to solder wires back together 92020
11/28/2015
Soldered Hazard Switch contacts back together 92020
11/29/2015
Installed New Left Side Windshield Bracket & Electric Windshield Switch 92020
12/15/2015
Install Seat Pins & Circlips 92020
12/15/2015
Installed H1 Projector Retrofit Kit from TheRetrofitSource 92020
12/19/2015
Installed Engine Crash Bars & Remander of Fairing Pieces 92020
12/19/2015
Removed Final Drive & Installed New Case O-Ring & Seal, Refilled w/ 80W90 Gear Oil 92118
2/27/2016
Flushed Front & Rear Brakes & ABS Modulator w/ New Brake Fluid 92118
2/27/2016
Installed New Rear Brake Pads 92118
2/27/2016
Installed New Rear Shinko Tire 92118
2/27/2016
Install Heated Grips w/ New Grip Rubber, pull tank for power to heated grips 92541
4/5/2016
Pictures are current as of today, taken outside work.
https://flic.kr/s/aHskzD3nVZ (https://flic.kr/s/aHskzD3nVZ)
Very open to offers, shoot me a PM or email.
$1500 firm, just bought this one's replacement.
