TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: clubserpent on August 11, 2011, 02:38:42 PM
Title: gas cap k75
Post by: clubserpent on August 11, 2011, 02:38:42 PM
I have a recurring problem on my '86 k75. Most of the time runs great, but at times seems to run only on 1 or 2 cylinders-appears to have water in gas. Water seems to pool under the gas cap after it rains . Is there a seal I should be changing? Any ideas?
Title: Re: gas cap k75
Post by: frankenduck on August 11, 2011, 03:03:41 PM
There's a kit you can buy at the dealer to replace all of the gas cap seals - part 16119062461.
Post by: ReneZ on August 15, 2011, 12:05:02 PM
And you'll want to make sure that the drain line for that is free and the cap with packing fitted such that the line is open at the top. It has a drain for the tank cover recess.
Post by: clubserpent on August 21, 2011, 11:38:54 PM
Thanks for the info guys. I'll check out the seals and drain
