TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Donmystic1 on March 10, 2016, 04:08:33 PM
Title: Brake light stays on
Post by: Donmystic1 on March 10, 2016, 04:08:33 PM
My 1985 K100rt's brake light stays on.occasionally I can shut the bike off and it will stay off on the next start. The fuklds are topped off. Is it a bad electrical connection.
Title: Re: Brake light stays on
Post by: Chaos on March 10, 2016, 04:39:25 PM
There is a little plunger switch by the front and back brake levers.  One of them is probably sticking.  Try squirting some silicon or wd40 on them, if lite is still stuck on unplug them one at a time to find the culprit.
Post by: Donmystic1 on March 10, 2016, 05:08:34 PM
I'll start at those two places. Thanks
Post by: Donmystic1 on March 11, 2016, 08:55:47 AM
I meant to say the light on the dashboard not the actual brake light. It goes out occasionally.
Post by: Laitch on March 11, 2016, 09:11:10 AM
You probably have weak wiring to the tail light assembly bulb contacts, dirty or fractured contacts, a short in the wiring to the brake lights, weak grounding or failing bulbs, Don. I've found the monitoring unit itself to be reliable.
Post by: Martin on March 11, 2016, 04:17:22 PM
The light on the dash lets you Know that your brake lights are being activated. It will stay on if either one of your brakes is not activating your rear light.
Regards Martin
