TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Folsoml on February 01, 2016, 06:58:42 AM
Thanks to Frankenduck and his awesome ABS Voodoo thread (http://www.motobrick.com/index.php/topic,538.msg1312.html#msg1312), I got the ABS system on my brick to re-boot! As the thread suggests, it took several times for it to finally "take," but it did. I found that, rather than holding the ABS switch down before turning the key, I should turn the key, THEN start holding the switch. That is what finally worked for me.
This a helpful post, folsom. Having something about abs in its title may be helpful for someone's search, too. Also, consider adding it to the ABS Vodoo thread.
My ABS on the '93 K75S kryder works just fine thank you. But should it ever go south I'll give this a try. Thx for posting.
