TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: CCalms on January 24, 2016, 05:53:44 PM
Title: Help me get my '85 k100 running again
Post by: CCalms on January 24, 2016, 05:53:44 PM
Here's a video of the bike's current condition
https://www.youtube.com/watch?v=-xGgObROiLs (https://www.youtube.com/watch?v=-xGgObROiLs)
Does anyone have any ideas? I really want to get out riding again!
Title: Re: Help me get my '85 k100 running again
Post by: rbm on January 24, 2016, 06:03:38 PM
Clean the starter as you mentioned and you probably will need new brushes in the process.  Have you gone through the electrical connections and checked that they are sound (i.e. used a good cleaner like DeoxiT)?
Post by: CCalms on January 24, 2016, 06:09:47 PM
I've gone at the main grounding point (the one that goes to the negative terminal) with some sandpaper but that's it. I've done some basic snooping around for damaged wires and I've checked various plugs (ECU, tank connection... I guess that's it). Any advice/links on where to look? I'll get some electrical cleaner.
Post by: rbm on January 24, 2016, 06:42:40 PM
The start motor is part of the grounding system for the electronics on the bike.  So, tackle that cleaning first to see if your symptoms disappear.
Post by: The Mighty Gryphon on January 25, 2016, 09:18:53 AM
It is worth the effort to get DeOxIt.  There are contact cleaners out there that dissolve plastic.  God only knows where you're supposed to use them since almost everything has plastic in it these days.  DeOxIt is the only stuff that is definitely known to get the job done without destroying everything else.
It sounds like you may have an incorrect fuel/air mixture.  Does the exhaust smell like raw gasoline?  Have you pulled the plugs to see what they look like?  With everything you have changed so far, I think I would start looking at the sensors that send mixture control signals to the computer.  Specifically, the mass airflow sensor and the engine coolant temperature.  The problem could be a loose connector, or a bad sensor.   There are threads here that go into a lot of detail on troubleshooting these parts.
Post by: CCalms on February 06, 2016, 12:53:25 PM
I've cleaned my starter, EFI plug, and main ground with DeoxIt. No more starter or headlight issues, but the bike still won't start. I'm tempted to spend money on new spark plugs (the current ones are not old, just dirty...) and fuel stabilizer but I think I would just be throwing away cash. There is some real issue that I need help locating.
Post by: Martin on February 06, 2016, 01:27:11 PM
After you have tried to start it are the plugs wet or dry? With a plug removed earth it and crank it over, do you have spark?
Post by: Laitch on February 06, 2016, 01:42:27 PM
Where is the instrument cluster?  Did the bike ever run well without It?  What is in its place?
To echo Martin here, does each spark plug emit a bright spark?
Is each spark plug connected to its correct coil fitting? How did you verify that?
Is each cylinder test port capped?
Did you perform the Hall Effect Sensor (HES) test recommended in response to your first post, or were you unable to get the bike running enough?
You've checked and eliminated certain causes by cleaning and replacing parts. An orderly measurement process seems to be indicated if sufficient spark is being delivered to the correct cylinders.
Watch this video.
https://www.youtube.com/watch?v=EgLR5qv7F8I
Post by: CCalms on February 06, 2016, 05:38:27 PM
Currently with full choke and no throttle the bike fires for 0.5-1 seconds and dies.
Post by: Laitch on February 06, 2016, 06:03:00 PM
The bike did once run quite well although with intermittent failures.
The instrument cluster was removed as it didn't work. I never needed to bypass anything and the bike was able to run without any cluster attached.
Just to clarify, CCalms, the bike was able to "run quite well" without the instrument cluster but had "intermittent failure." Please describe what "quite well" means and describe the intermittent failures, their frequency and their duration.
Post by: rbm on February 06, 2016, 06:36:31 PM
Have you tested the items that Gryphon suggested -- temperature sensor in the stand pipe and the mass airflow sensor.  Follow the steps outlined in Bert's diagnosis page  http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/bike-wont-start1.htm
specifically for the temperature sensors.  Also, remove the MAF and make sure that it is operating properly, both mechanically and electrically as per Bert's guidance.  The throttle hesitation seems to me to point towards fuel starvation.  That can come about from blocked fuel delivery (all of which you have replaced except for the pressure regulator) or poor fueling (which you need to check).
Post by: Brad-Man on February 07, 2016, 08:09:01 AM
I would definitely run a check on the AFM...
Post by: tsnap on February 07, 2016, 03:42:18 PM
A tip I learned years ago, when everyone insisted that I NEVER try to clean my MAF on my  multiport 1989 Z28.
When cleaning, use brake cleaner  sparingly, carb cleaner contains lube(oil that can affect heating and cooling of the sensor wire) which leaves a film.
Also , flush part in reverse, pushing contaminants out in reverse of normal air flow.
Has always worked for me, FWIW
tom
Post by: K1300S on February 07, 2016, 05:20:06 PM
When cleaning,  use spray cleaner designed for MAF, not carb or brake cleaner.   It is available at any auto parts store.
Post by: tsnap on February 08, 2016, 09:19:52 AM
oops, I meant starter fluid contains cylinder lube.  But now i am getting a can of maf scrub.  thanks.
 hard for old farts to keep up with new products.  Heck, do plumbers even carry big wrenches anymore?  For some reason, my dad thought I NEEDED TO KNOW HOW TO THREAD PIPE BY AGE 8?
RECENTLY HELPED ON A SHARKBITE PROJECT....GEEZ, WHATS NEXT.....PUSHBUTTON PHONES????
TOM
Post by: Brad-Man on February 08, 2016, 05:15:28 PM
Doesn't he have an Air Flow Meter (has a spring loaded flapper to measure airflow)
If so he needs to measure the resistance at various points...
Post by: rbm on February 08, 2016, 07:50:54 PM
AFM,MAF, MAS ... it's so confusing.  Yes, he's got the barn door.  It sometimes fails because it's electromechanical in nature; a wiper rubbing against a resistive circuit.  So, dust gets in the way, springy metal stops being springy after 30 years, etc. etc.  There are tests that can be performed which are outlined in Youtube videos.  These same videos also show repairs that can be made in case something isn't right.  If the AFM/MAF/MAS/what-ever-you-want-to-call-it fails to work right, it will upset the fueling and may show up as the symptoms here.
Post by: CCalms on February 09, 2016, 01:50:56 PM
Took the multimeter to my EFI plug today. The resistance from the water temp sensor was correct for the ambient temperature.
Post by: The Mighty Gryphon on February 09, 2016, 01:55:38 PM
Hoping this fixes it.  Please keep us posted on how things work out.
Cheers
Post by: tsnap on February 09, 2016, 02:35:08 PM
waiting for a post that says it runs like a striped ape,better than ever,  and that he loves his bike so very much again!!
LOL, thats how it works for me!
tom
Post by: rbm on February 09, 2016, 03:39:06 PM
Here's hoping it works. :beer:
Post by: Brad-Man on February 09, 2016, 04:05:00 PM
Wonderful news !
Hope that's all it is.
Post by: gpcrane on February 13, 2016, 03:38:57 PM
I hope the AFM solves your problems.  I too have been having grounding issues.  It was the classic starter motor would not work, the load shedding relay was not pulled in.  So I removed the starter motor and cleaned out 29 years worth of carbon.  I measured the brush length, the shortest one was 10mm, according to my Haynes manual the min. length is 6 mm.  I put everything back together and the bike fires right up, good as ever...until...
As soon as I push the bike off the center stand the engine dies.  I try starting again, the starter motor turns but no ignition.  Back on the center stand and it firers right up.  After a few times going back and forth with the center stand it is running off the stand and I ride a way for a test ride.
The bike feels normal, running great.  I stop for gas, and have no problems starting the bike and coming off the center stand.  I ride for a few more miles and the bike begins to cut out, lights stay on.  Then the bike dies.  Once again it will fire up on the center stand but dies off the stand.  I go back and forth once again and ride it home with no problems.
My first plan of attack with be to clean all around the center stand and check all grounds.  Pull the EFI connector and clean it up real well.  Any other thoughts out there?
Thanks.
Post by: John Lang on February 13, 2016, 09:18:24 PM
Is there a side-stand cutout switch on that model? If so, is it somehow shorting out when the bike rolls off the center stand?
Post by: gpcrane on February 13, 2016, 09:43:49 PM
It's an 87 K75 s.  As far as I can tell I do not have the switch, but it sure acts like I do.  After cleaning under the bike and cleaning various connectors the problem is now worse.  I have a hard time getting it to fire up even on the center or side stand.  Once it does start coming off the stand kills it.  Lights stay on and starter motor still works, no ignition.
Thanks, Greg
Post by: K1300S on February 14, 2016, 07:48:19 AM
Sounds like loose connection, bad kill switch, or bad fuel pump.
Post by: Laitch on February 14, 2016, 08:07:14 AM
Start a separate thread for your mechanical problems so that answers aren't confused with CCalms's issues on this thread that he started.
Post by: gpcrane on February 14, 2016, 01:03:34 PM
I started a new thread called "Run while on the center stand".
Post by: CCalms on February 18, 2016, 08:18:25 PM
Unfortunately, replacing the faulty air flow sensor with a functioning one did not solve my problem :(
Post by: Laitch on February 18, 2016, 08:39:17 PM
Have you performed the compression and vacuum tests yet or have you decided to replace every part of the engine until it works correctly, CC? :hehehe
As far as I'm concerned, and that may not be very far, I think a recap is in order here. How about listing—in a simple linear form—everything you've done so far to remedy this?
Post by: CCalms on February 23, 2016, 01:38:42 PM
I feel the vane in the air flow sensor oscillating a good amount as the bike tries to idle. Should the vane be more steady? Is this evidence of an air leak? If I hold the vane open with my finger, the bike idles very nicely.
Post by: rbm on February 23, 2016, 05:37:33 PM
https://www.youtube.com/watch?v=RYKT_Vr0snU
It should not oscillate at idle; it should be steady.  Probably indicating a leak somewhere in the intake or stiction in the mechanism.  Search Youtube for videos on troubleshooting the AFM if you are not immediately successful in isolating a leak.
Post by: The Mighty Gryphon on February 23, 2016, 07:25:37 PM
Since it is oscillating I am going to guess the problem is in 1 or possibly 2 cylinders, and not in the airbox or the breather.   One of the cylinders is not pulling in air through the flow sensor.
Can you do a compression test?  That would quickly identify a bad cylinder if the problem is rings or a bad valve.  A bad valve is probably going to be a burnt exhaust valve that allows air in from the exhaust system.  If that is the problem, I would expect the spark plug in that cylinder to either be more or less wet that the others because the flow of fuel will not be the same as the cylinders that are getting good air flow from the intake plenum.
If not a bad valve or rings, the problem is going to be either a leak above or below a throttle body or possibly a problem with the linkage that does not open one or more of the butterflies.
Post by: tsnap on February 23, 2016, 07:36:08 PM
would pulling  and reconnecting plug wires while running  and watching the flapper assist in this diagnosis?
tom
Post by: Laitch on February 23, 2016, 08:13:59 PM
tom
That certainly could be added as another stop in the tour around Robin Hood's barn, tom.  :popcorm
Post by: tsnap on February 23, 2016, 08:31:55 PM
going around the barn a few times could result in meeting ALL the farmers daughters, rather than limiting oneself to the one working on the most demanding  udthers
Post by: Laitch on February 23, 2016, 08:37:49 PM
going around the barn a few times could result in meeting ALL the farmers daughters, rather than limiting . . .
They'd all be charmed, I'm sure but packing a lunch is essential. It's a pretty big place.
Post by: CCalms on February 25, 2016, 06:26:18 AM
I definitely should do a compression test. The bike has a confirmed 20k miles so I am not too worried about the valves, but that's obviously no reason not to do an easy and important test.
Post by: tsnap on February 25, 2016, 09:17:48 AM
Never let the facts (or data) get in the way of a good theory.
tom
Post by: The Mighty Gryphon on February 25, 2016, 10:19:09 AM
The hard plastic manifolds below the throttle bodies are visibly cracked and audibly leaking. I've changed all my other leaks, and I'd be happy to change these out too, but BMW didn't have the foresight to make these manifolds out of rubber by '85 and the hard plastic ones are a bit expensive. Unfortunately I'll be leaving the country for two months but those will get changed when I get back.
That is what I was expecting you would find.  Those cracks and the unmetered air they let in cause a real lean mixture that won't run worth a crap.  If they are at the point where they are starting to break up, I wouldn't be surprised that the more it runs, the worse the leaks are.  A temporary test to see if that is the problem would be to clean them well, and then put a coat of silicone caulk on them.
I have found pretty good used lower bushings on eBay for very cheap compared to new ones from the factory.  They are cheaper when you buy them attached to the throttle bodies along with a fuel pressure regulator and a throttle position switch.  Sometimes you can even get a "choke" indicator light switch in the bargain.  I have bought K75 throttle bodies with all the above stuff for less than the price of one new lower bushing.
Post by: TimTyler on February 25, 2016, 12:46:31 PM
If you buy a used throttle body setup, find one that still has the blue paint on the butterfly adjust screws. That way you'll know it probably hasn't been adjusted improperly.
Post by: caveman on August 28, 2016, 08:53:46 AM
CC,
So what have you done since Feb. I am trying to bring a 85 100 back from the dead myself and am having the same symptoms as you (starts but dies off idle). Reading this thread gives me a few things to try and maybe we can help each other out.
