TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: leecow on July 21, 2011, 01:28:49 PM
Hey folks,
If one wanted to experiment with shock preload settings but did not have the original adjustment wrench (http://i1221.photobucket.com/albums/dd470/Motobrick/gen_maint/transoillevel.jpg), what might be an effective alternate tool? Fairly certain the shock in question is the original.
Hey folks,
If it's a stock shock then you could just buy a shock wrench from Ride Worst. Part # 71112315897. About $10 or so.
i gotts an extra you can have... you pick it up when we are in renton wa august 8 thru 12...
Thanks Duck and J O. Completely missed seeing the wrench in the fiche.
J O, I'm backpacking 8/8-10 but can meet up later that week for a burger or somethin'.
If you're not backpacking until 8/8 then you should come pay a day visit at the cabin on 8/6. I can send you home with some extra fresh Dungee too. The cabin's only about 45 minutes from the Kingston ferry dock.
Yep, I plan on making it out for Saturday at least. Might be able to get out Friday night if I play my cards right but that will depend on timing and the ferry line once I can get moving.
the ferry line
Just ride up to the front of the line.
I knew MC's loaded first but didn't know we could skip right to the toll booth ;)
Can you post a link for Ride Worst? My tool kit is missing the wrench you check tranny oil w/. Thanks!
http://www.ridewest.com/custompage.asp?pg=hours (http://www.ridewest.com/custompage.asp?pg=hours)
The shock wrench for measuring tranny oil only came with the two valve tool kit: part 71112300061
The four valve bikes tool kit came with a separate L-shaped dipstick: part 71112316195
I made my own dip-stick the other day. I found it difficult to get a "reading" off just a metal stick, so I added a bit of black heat-shrink tubing to it which made it much better. Then I added a piece of red heat-shrink offset by 10 mm so as to mark the "max" level. Worked out quite well. Just hope the heat-shrink never falls off into the transmission... :D
That hook wrench for 2v is NA at: Max, Bob's, and RideWest. Bob did inform me that a Canadian dealer has them in stock, 5 of them. Make that 4 now.......................
SM CYCLE ph 250 474 2088...........about $14 plus S&H.
