TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: broberg on January 10, 2016, 06:55:00 AM
Title: Koso DB-03 or other aftermarket gauges that have gear indicator
Post by: broberg on January 10, 2016, 06:55:00 AM
Hi!
Is there any one on the web (here or other forums) that has tried getting full functionality on an aftermarket dial? (Ie almost as the stock cluster but in a smaller format)
I found the DB-03 have lights and indicators for almost everything as the stock cluster has (I think, just made a quick check).
I'm guessing there will be quite a bit of tinkering getting it to work with the stock sensors, so that's why I'm wondering if someone have tried it?
http://www.koso.com.tw/products-detail.php?lang=en&id=982
(http://www.koso.com.tw/uploads/images/d7ea73eacf92a4a408497308240c2b61.jpg)
Title: Re: Koso DB-03 or other aftermarket gauges that have gear indicator
Post by: rbm on January 10, 2016, 09:42:14 AM
I've built circuits that convert the gear position switch on the K-bike transmission into a signal compatible with aftermarket gauges that have gear inputs.  My circuit has been tested with an aftermarket gauge sold on Ebay which includes a gear display.  Video below; watch the gear indicator.
https://www.youtube.com/watch?v=JtOjezntjKM (https://www.youtube.com/watch?v=JtOjezntjKM)
However, the Koso line of gauges don't have gear inputs; they calculate the gear number based on engine RPM, road speed and user programming (see Section 4-12 of the Koso installation/operation manual (http://kosonorthamerica.com/instructions/BA038000.pdf)).  As for detecting neutral gear (which you will need in any case), you have to do one of several things:
The Koso DB-03R fuel gauge is compatible with the K-bike fuel gauge if you perform the published modification to the sender (http://www.k100-forum.com/t9265-messing-with-the-in-tank-fuel-sender).  Most of the other signals from the K-bike should work with the Koso gauge.
Post by: broberg on January 17, 2016, 04:09:42 AM
Aahh I love it when people share their knowledge!
Thank you very much!
But I don't really get why you would have a "guessed" gear indicator as the Koso has, it sounds unreliable
Post by: pablooo on April 11, 2016, 10:37:36 PM
RBM, Are you still making circuit boards? I have just purchased a speedo just like you linked and I have seen the link for this (http://maru-labs.com) but I never got a reply for the e-mail and such.
Many Thanks,
Pablo
Post by: Bluebrick on June 16, 2016, 09:33:02 PM
Hey broberg did you end up installing the koso db-03
