TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: ramnaam on December 09, 2015, 09:58:52 AM
Title: Estimated weight? K11/K100
Post by: ramnaam on December 09, 2015, 09:58:52 AM
Has anyone weighed a k100 or k11 without fairing and ABS deleted? Or any condition close by. Or could anyone estimate the weight?
Title: Re: Estimated weight? K11/K100
Post by: F14CRAZY on December 09, 2015, 11:49:55 AM
My K75c with its Pichler full fairing, side cases, and 35L top case is 608 lbs
Post by: Laitch on December 09, 2015, 12:55:18 PM
This site gives the weight of a naked K100 with a full fuel tank. It doesn't specify whether it has ABS brakes.
http://www.bmbikes.co.uk/specpages/K100.htm
Post by: Laitch on December 09, 2015, 01:08:15 PM
If data isn't coming in fast enough for you, ramnaam, you can go to this site and add up the weight of the various components that interest you.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51754&rnd=07012015 :sip:
Post by: rbm on December 09, 2015, 06:28:57 PM
Assuming you're talking the K100RT fairing.  Looking up specs for the bikes -- RT (http://www.motorcyclespecs.co.za/model/bmw/bmw_k100rt%2083.htm), Naked (http://www.motorcyclespecs.co.za/model/bmw/bmw_k100%2086.htm) -- the difference in weight for the fairing is about 14KG / 31 lbs.  Add in the weight of ABS of about 11 KG / 25 lbs.  means the equipment delete will net you about 25 KG / 56 lbs. savings in weight.
Post by: Snowman on December 11, 2015, 09:15:18 AM
I think the ABS weighs more than 25lb. I was really surprised when I picked up the box of components after removing ABS from my K11LT, it was a 'lift with your knees moment'. I might throw it on a scale and see.
Post by: Laitch on December 11, 2015, 09:29:37 AM
MAX BMW lists K100RS ABS modulators at around nine pounds each.
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51709&rnd=07012015
Post by: ramnaam on December 13, 2015, 08:10:36 AM
Thanks all, great feedback
