TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => Project Custom Motobricks => Topic started by: klhoskins on October 25, 2015, 01:06:47 AM
Title: '90 K75 Cafe build... Getting there!
Post by: klhoskins on October 25, 2015, 01:06:47 AM
So the '90 K75RT cafe build is coming along nicely. I need to sort out the exhaust and rearsets and then it's just small stuff.
Title: Re: '90 K75 Cafe build... Getting there!
Post by: KRider on October 25, 2015, 04:42:50 AM
Wow looks nice!! Great job you done there.
Post by: drut on October 25, 2015, 04:49:28 PM
"Wow looks nice!! Great job you done there."
+1 bike has "attitude"
Post by: Laitch on October 28, 2015, 09:53:16 AM
Is the right fork tube extended more than the left?
You're sure making a nice looking machine.
Post by: klhoskins on October 28, 2015, 12:29:49 PM
Thanks Laitch... I didn't notice any issues with the folk legs and it's probably just the gaiters that are uneven. I plan on pulling the fork legs/triples and removing the unused tabs as well as adding some preload and 10w fork oil.
Still in the works;
~ Shorten the exhaust
~ Change out the rearsets
~ Install stainless lines
~ Remove tabs from the front of the gas tank
~ Resolve the reversed fuel indicator issue
~ Dial in the MPH/Tach readings
~ Seafoam the engine and clean injectors.
~ New rear shock
Post by: Laitch on October 28, 2015, 12:37:16 PM
I was looking at the amounts showing above the tree—probably just the angle of the image. I hope you'll do a video of the finished product in action.
Post by: klhoskins on October 28, 2015, 12:46:10 PM
Definitely good above the triple... Double checked it when I lowered them.
Post by: Laitch on October 28, 2015, 12:58:42 PM
10-4
Post by: TrueAce on November 30, 2015, 06:10:22 PM
Very clean look!  Where have you hid the battery, and what brand are you using? Also, where did you source the seat?
Post by: klhoskins on November 30, 2015, 06:41:52 PM
Battery is an Antigravity 16 Cell (should have got the 12) and it's not hidden. It's in the triangle opening laying down flat.
The seat I made myself but had it covered at a local upholsterer.
Can't wait to post the updated pics but need to finalize a couple things. Stripped an polished the aluminum tank, new custom made rearsets, re-shaped front fender from an '86 painted with an aluminum finish, stainless lines all the way around and a crossover exhaust to the right side for a fully exposed rear wheel.
 :2thumbup:
Post by: TrueAce on November 30, 2015, 07:37:11 PM
Look forward to seeing the update photos. You have done a fantastic job!
Post by: kris on November 30, 2015, 07:58:07 PM
Nice, nice looking bike! Always a great option on the Ks...I actually don't think the stock pipe looks too bad on the bike. Cross-over will be cool, though. Good luck!
Post by: K1300S on November 30, 2015, 09:03:31 PM
can't quite read the sidewalls...what type/size tires are those?
Post by: Superfly on December 01, 2015, 03:08:04 PM
Nice looking bike!  Couple questions:
- Where did you put your ignition switch?
- What instrument cluster do you have?
Well done!
Brian
Post by: klhoskins on December 01, 2015, 04:28:26 PM
Tires are Kenda Challengers and I'm not sure on the sizes.
Went with the Acewell speedo.
And the ignition switch went here.
Post by: Andrewck on December 02, 2015, 12:14:44 PM
how is the seat attached?  Would love to see some more detail there.  Great looking bike
Post by: Markus77 on December 08, 2015, 05:33:23 PM
The bike looks fantastic! Really looking forward to seeing the updated pics and what you've got for the exhaust and rear sets. I've just picked up a 94 K75rt and am in the process of stripping it down/ordering parts. Hope it can turn out even half as good as this one - great work!
Post by: klhoskins on December 08, 2015, 08:57:27 PM
Just got her back from getting the exhaust collector built. Came out pretty good but is loud as hell :yow.
Post by: Markus77 on December 08, 2015, 09:19:17 PM
Wow - looks great man. What kind of rear sets are those? Also, how difficult was it to route the exhaust to the other side? Looking forward to seeing a few more pics of the whole bike when you get chance. Nice work
Post by: K1300S on December 08, 2015, 09:47:24 PM
Looks like a great way to melt both left and right boots while slowly going deaf. .. ;-)
Post by: klhoskins on December 08, 2015, 10:03:01 PM
That is exactly what I was shooting for Mlytle :2thumbup:
Actually, I cruised it for a while then sat for a while at idle and surprised there were no heat issues.
Post by: klhoskins on December 12, 2015, 03:41:35 PM
Did a quick polish on the tank and snapped a couple more pics. Just need to sort out the rear shock and stiffen up the front and it will be done-ish.
Post by: Markus77 on December 12, 2015, 03:56:43 PM
Looks great - thx for posting the pics - been following your build and am really impressed! Quick question for you, when you were connecting your acewell, did you cut the wires from the harness that connected to the old speedo cluster or did you find a way to interface the acewell with the harness? I'm a bit stuck on this and don't want to cut it if there is another easy solution
Post by: klhoskins on December 12, 2015, 04:31:05 PM
Best bet is  to cut the harness and wire it up direct. Do a search on this site for the acewell and you will find the specifics on wiring it up. A few things to keep in mind.
You will need to build a circuit to deal with the cluch/gear position ignition cutoff
When connecting the tach wire make sure to use the provided resistor inline or the reading will "flutter"
You will need to use the provided magnetic pickup to a point on one of the wheels as the stock pickup will not work
You will need to pull the fuel sender from the tank and reverse a part to make it work. Instructions also can be found on this site
Post by: Markus77 on December 12, 2015, 04:48:44 PM
Thanks for the helpful tips! Also had one of these recommended to me: brotbox http://maru-labs.com looks pretty cool. I'm inquiring about cost/shipping etc and then will see if it's worth it
Post by: TrueAce on December 12, 2015, 06:53:08 PM
Very clean build.....Good job! What's the clearance on the rear tire and exhaust?
Post by: klhoskins on December 12, 2015, 07:13:45 PM
It's about 1.5". No heat issue.
Post by: klhoskins on December 12, 2015, 09:52:41 PM
Hey Markus77, I didn't even know that brotbox existed. That definitely would have saved me some time and would have had a way better end result
Post by: Scud on December 13, 2015, 12:05:30 AM
Damn, I thought it was looking great at the first post. Now it's truly exceptional. I'd like to come check it out sometime - you can't be more than 15 miles from me.
Post by: klhoskins on December 14, 2015, 06:27:32 PM
Hey Scud, yeah we could meet up somewhere on the coast on the weekend. Just lemme know  :2thumbup:
Post by: Markus77 on December 15, 2015, 07:23:39 AM
I've put in an order for the Brotbox - it's coming from Switzerland but I'm excited to see how it works - I'll keep you posted. Really like the way your bike turned out - I also want to get the exhaust on the other side but that's way beyond my skills. Hoping to have a friend come and have a look over the holidays to see if he can help with that. What/where did you find your exhaust? I was worried about the heat issues but you mentioned it wasn't bad so I'd like to try it. Please let me know when you get a chance, Thx:)
Post by: klhoskins on December 15, 2015, 11:14:12 AM
On the exhaust I pulled the center stand, trimmed all the metal off the case and bought the pipe. Had a local exhaust shop modify the collector and weld up the bend. My part was easy!
So I've had the bike out for a couple long rides now. I've noticed a trend... Some people really dig the bike like I do and then there's the people that comment "Hmmm, that's different". I'm almost offended but then I remember that different is one of the main reasons I did a K bike build.
Post by: TrueAce on December 15, 2015, 07:56:02 PM
Betcha that's cause people don't recognize it........BMW's have jugs ,right? Just ask folks who comment "Do you ride? Whatcha got?" and you'll find either they don't ride or they don't ride a BMW! As the Ural folks say, you have to remember the UDF.......Ural Delay Factor from all the curious people. You are just experiencing KDF! Beautiful bike you got there!
Post by: kris on December 16, 2015, 11:45:43 AM
I don't care if people like my bike! I know what I have, you know what I have and we know what we have! A little off-beat, nicely made (understatement), a little quirky, nimble and big in the "smile on my face" department! They ain't buildin' 'em anymore and I feel lucky to own one. That'll do....
Post by: TrueAce on December 16, 2015, 12:34:29 PM
You just go fast! Confusion to the enemy!
Post by: nilspedotti on March 09, 2016, 06:43:03 AM
Very nice bike! How is your experience with the Antigravity Battery? Does it charge alright or did you have to change anything besides installing it? Thanks in advance!
Post by: gazman on March 09, 2016, 10:00:52 AM
Now that is one good lookin bike :2thumbup:Nice work mate
Post by: klhoskins on March 09, 2016, 10:42:45 AM
No issue at all with the Antigravity Battery.
Post by: klhoskins on March 09, 2016, 01:22:48 PM
Here's what she looks like today... For sale in the San Diego area if anyone is interested.
Post by: TimTyler on March 09, 2016, 02:16:48 PM
Nice looking bike.
Are you sure that instrument cluster is mounted securely enough?  :yes
Post by: klhoskins on March 09, 2016, 04:24:46 PM
Hey Tim, you have no idea how many times I've had it on my list to replace those bolts with smaller black countersunk bolts.
Post by: TrueAce on March 09, 2016, 05:41:05 PM
Nice job! Very clean and sharp! What's the price?
Post by: klhoskins on March 09, 2016, 06:01:03 PM
Asking $4,500.
Post by: TrueAce on March 09, 2016, 06:51:05 PM
You are offering a lot of motorcycle for a fair price considering R Nine T's are going for $15,000. Very impressed with your attention to detail. Good luck and let us know how you do with the sale.
Post by: Markus77 on March 11, 2016, 07:20:43 AM
I really like the way it turned out - as mentioned before great attention to detail. I've looked at your build many times and I think you've done a great job. I don't know the California market, but I'd say if someone buys this for $4500 they are getting an amazing deal. I think given the work you've put in you should ask a bit more:)
Post by: sj2000 on March 11, 2016, 02:36:49 PM
Markus what is this brotbox? Is this additional for aftermarket speedo? thanks.
Post by: Markus77 on March 11, 2016, 06:20:55 PM
It's designed to be used with an aftermarket speedo on the K bikes. It allows functions like starting the bike without having the clutch pulled, gear indication, low fuel level. I can't comment on how it works as I haven't gotten my bike to the point where it's connected yet, but the actual wiring of it is pretty straight forward. I'm hoping to have the bike done in the next 2 months and then I can let you know how it works.
Post by: sj2000 on March 12, 2016, 04:41:27 PM
Could you please take a picture when you connect the cables, I am going to use acewell 2853, which one are you going to use?
Post by: rmorris on April 20, 2016, 09:47:19 AM
great looking bike. what type of a coolant bottle is that??
