TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: sfrligo on September 13, 2015, 10:33:49 PM
Title: K75 Mystery Spring
Post by: sfrligo on September 13, 2015, 10:33:49 PM
Hello all,
I am reassembling my 1994 bmw k75, and have a spring left over that I just can't remember the purpose of. I don't recall detaching it form anything, it must've come off while I was taking parts out. It's too clean to be a part of the stand, and too small for much else. It's about 2 inches long (see photo.)
While working this time, I took apart everything down to the main seal: the stand, wheel, rear drive, shaft, transmission, battery, battery cage, seat holder, foot plates, and clutch out.
Any guesses as to where it goes? Thanks!
Title: Re: K75 Mystery Spring
Post by: The Mighty Gryphon on September 13, 2015, 10:39:12 PM
I could  be wrong, but I think it has something to do with the rear brake pedal.  Too late to go out and check my K75 to be absolutely sure.
Post by: sfrligo on September 13, 2015, 10:40:18 PM
thanks, that rings a bit of a bell. Could you check tomorrow if you think of it?
Post by: The Mighty Gryphon on September 13, 2015, 10:46:30 PM
I'll take a look before I head out to work.
Post by: HYPERR on September 13, 2015, 11:03:33 PM
It looks like the tension springs on the sidestand.  There should be two on there.  Are you missing one?
Post by: sfrligo on September 13, 2015, 11:09:13 PM
thanks, it does look like those: but those are about twice as long, and I do have both.
Post by: HYPERR on September 13, 2015, 11:11:54 PM
Well they are stretched quite a bit so I figured it would shrink to about that size when detached?
Post by: sfrligo on September 13, 2015, 11:13:27 PM
good point! but no, they're both there. they're also way dirtier due to road gunk. Thanks though!
Post by: Motorhobo on September 14, 2015, 06:42:59 AM
Nothing new under the sun...
http://www.motobrick.com/index.php/topic,6238.msg41685.html#msg41685
Post by: The Mighty Gryphon on September 14, 2015, 11:28:31 AM
It looks like the spring hooks around the pedal and holds pedal in up position.   Not sure how it connects behind the foot peg plate.   Odd that it isn't shown on any of the parts diagrams.
Post by: rbm on September 14, 2015, 10:11:17 PM
One end hooks to an "L" shaped bracket attached to the brake pedal.  The other end hooks on the center stand, on the bar between the two centre stand springs.
