TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: sfrligo on September 03, 2015, 09:57:58 PM
Hello,
I stripped my 1994 K75 down to the main seal. There doesn't seem to be much coming out of it (see photo) but it might be 20 years old, and I thought I'd replace it while I was in there. There was some gunk in and around the clutch, but nothing coming out the weep hole.
I know the seal sits over some ball bearings. Is there a way to just buy the replacement seal without the bearings? anyone have advice for how to find that? I can find the unit with the bearings for $133, but there's no way the seal alone should cost that.
Thanks!
Sure you can..
(06) 11 11 7 666 186 SHAFT SEAL - 50X80X10
(http://www.maxbmwmotorcycles.com/fiche/Diagrams/B0000171.png)
Part #6, about $34
Get the $2 O-ring too. # 11211460456
That o-ring alone is probably the real cause of the oil leak....................Not uncommon at all.
Check the gaps between the bell/mid-housing, and the engine block. You might find some pooling in those "pockets". You do have a leak. (Isn't the inside of the bell/mid housing supposed to be silverish/metalic aluminum? It's black/covered in oil in you pic) It will only get worse.
