TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: kioolt on September 03, 2015, 01:43:21 PM
I just put speedbleeders on my 91 K100LT front wheel caliper and ABS unit. Everything went fine as far as bleeding goes. I did notice that the OEM bleeder screw on the ABS unit is different than what I call a standard bleeder screw. There is an o-ring to the right of the threads and between the threads and the o-ring is what appears to be a relief cut for fluid flow. Please take a look at the image below. Does anyone know if the speedbleeder is an ok substitute for this and that my ABS will still function as intended?
(http://i1342.photobucket.com/albums/o778/kioolt/100_1352_zpspl7l2b2t.jpg)
Bump, as I'm planning on doing the same.
On the speedbleeders site, it lists a different part number for them, but with the same dimensions, for what that's worth.
I bought 2 SB1010's and 2 SB1010S's when I did mine. The s at the end just stands for short. If memory serves me correctly the short ones go in the wheel calipers.
