TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: jensk on August 29, 2015, 08:39:07 AM
Title: why are this one rear wheel bolt colored
Post by: jensk on August 29, 2015, 08:39:07 AM
I had the rear wheel of to do a FD spline lube today. I discovered that one of the wheel bolts are colored.
Is there a reason for just one of the wheel bolts are colored green?
Title: Re: why are this one rear wheel bolt colored
Post by: johnny on August 29, 2015, 08:46:36 AM
the green one goes in the middle hole... looks like you are missing a non painted bolt and the spacer for the center bolt...
Post by: Inge K. on August 29, 2015, 09:13:57 AM
The center bolt you find on paralever models, it's not used on monolevers.
If you look around you find a green dot on more bolt heads, whichs says they are checked
with a torque wrench before leaving the assembly line.
It's the same bolts that should be checked at specified intervals according to the maintance schedule.
Post by: johnny on August 29, 2015, 09:31:01 AM
 :hehehe
Post by: jensk on August 29, 2015, 10:50:51 AM
Thank you for the reply. Can't find any green spots on the other three bolts. Anyhow it doesn't matter since i torqued them to the specified Nm's
Post by: Scott_ on August 29, 2015, 01:41:43 PM
You will most likely find the green dots/paint on other bolts around the bike... rear shock mount's, fork triple tree bolts, etc.... you get the idea.
