MOTOBRICK MARKETPLACE => FS WTB WTT ~ Bikes ~ Parts ~ Gear => Topic started by: jay1622 on August 17, 2015, 10:42:40 AM
Title: WTB Something that will Isolate the Clutch
Post by: jay1622 on August 17, 2015, 10:42:40 AM
Anything floating around out there for clutch servicing? I'm guessing I could impact wrench the nut on and off, but I'm thinking I'm going to do it the old fashioned way... The correct and patient way.
Title: Re: WTB Something that will Isolate the Clutch
Post by: Scott_ on August 17, 2015, 05:58:35 PM
So you are looking for a jig to hold the clutch housing from turning so you can wrench off/on the holding nut?
I use a hunk of 2x4 personally.
Post by: F14CRAZY on August 17, 2015, 06:01:40 PM
I think I used the rubber handle of a hammer
Post by: jay1622 on August 17, 2015, 06:05:55 PM
Yes, that is exactly what I am hoping to do. Since I posted this, I have seen a few makeshift holding implements made out of bar stock and a grinding wheel by the looks of it. It looks easy enough, but I'm guessing the 2 x 4 tool is an accepted method; can probably figure out where to place it and how much to use once I get in there.
Was the hammer handle used on a 75? I know you can do that with the 100s,  but I probably would need a reference picture for using a hammer handle on the 75.
Post by: F14CRAZY on August 17, 2015, 09:13:51 PM
I don't think I took any photos but I wedged the handle in there somehow
Post by: rbm on August 17, 2015, 10:25:12 PM
Helps to search the Lieberry card catalog:  Check out Clutch Work without special BMW tools (http://www.motobrick.com/index.php/topic,4975.0.html)
Post by: MonkeyMcBean on August 18, 2015, 10:46:36 PM
Bad link. Not yours, but the one you linked to.
Post by: Scott_ on August 18, 2015, 11:17:52 PM
The link may be bad, but you can download the .pdf file as it is hosted on this site.
Post by: MonkeyMcBean on August 18, 2015, 11:38:04 PM
Ah! I see!
Post by: jay1622 on August 18, 2015, 11:45:46 PM
S C O R E !
Lowe's had bar stock (1"x1/4"x36") on sale for $5.00. There's a great DYI clutch isolater diagram in an old Haynes manual I have. My metal cutter, a drill, some good metal bits, a punch, a grinder and a finishing wheel should do just the trick. And, if I goof it up too bad, I've got plenty to go back to the cutting board with.
