MOTOBRICK.COM => Welcome To Motobrick.Com => Topic started by: Bryan_h on August 16, 2015, 02:14:40 AM
First off thanks to this forum and it’s members. You have been very valuable in researching my next purchase.
Looking at buying a 93 BMW K1100LT. I’ve owned a number of street and dirt bikes over the +30 years of riding. This would be the first BMW and my first street bike in a while.
The bike I’m looking at looks good from 10’ away. The current owned said he has not done much with the bike other than change the oil. It has 70k miles. Is stock except for an aftermarket wind screen, a Corbin seat along with a clean stock seat, a Gerry rigged aftermarket radio along with the stock radio. The paint is in good condition with a few scratches, noting indicating it’s been down. No corrosion on the forks, visible frame, inside the tank, or under the seat. I did not take the front fairings off. All the lights work. Bike started easy and ran smooth and quiet. No play in the wheel bearings or steering stem. I did not test ride. No leaks on the drive shaft or anywhere else except as noted below.
Now the bad. In addition to needing a rear tire and brakes all the way around, it has an oil leak in the underside’s rear drain hole, slight leak in the front master, the ABS light stays on and my biggest concern a cracked header pipe at the collector. It is a hairline crack that goes around the pipe (lower left side looking to the rear). I could not hear any additional exhaust noise or any rattling due to the crack.
We discussed price and agreed to $1700USD dependent on a few days thought and a test ride if I come back.
Is the cracked header pipe a deal breaker? Will the crack get worst? My research on this site and others indicates that folks have had very limited success in repairing these and aftermarket exhausts are difficult to obtain and pricey. If I knew the problem would not get worst I’d drive it as is. I don’t want to drop a bunch of $ into an exhaust for a bike with limited value.
Thanks in advance for your thoughts and opinions.
Bryan H
greetings bryan underscore h...
welcome to motobrick.com...
if it was me... i would wait for a better motobrick... very good condition motobricks can be had nearly everywhere for approx $3500... example here (http://duluth.craigslist.org/mcy/5170122580.html)...
the reason is this thing is a heap... its gonna need a clutch and all the stuff that goes with that... and that exhaust may become a real nightmare... non functioning abs can make you go crazy... new front brake master... gonna need stainless brake lines... and on and on and on...
just sounds like a heap to me... proally needs all new rubber and all kinds of other stuff... i can see having another $3000 into this thing real fast and still needing more...
this is a $500 motobrick at best...
just one motobrickers opinion...
I should add. I'm not looking for a beauty queen or a perfectly sorted bike. I do want a safe, reliable and fun bike. Prefer something that I can ride after a weekend or two of replacing fluids, brakes and tires. Fixing the bigger items over the winter, clutch masters...I'm not opposed to wrenching on a bike myself and I have the ability to make all of the mentioned repairs or replacements myself except welding an exhaust. I've put together more than one bike that came in a crate. Couple of hundred bucks in replacement parts I can work with. $3200 in bike and parts and it seems like there are better options. That's why my primary concern is the exhaust. If it will function indefinitely with a crack it may be a decent deal.
With the cracked exhaust, you will have exhaust leak, more backfire on deceleration, and you will have to check your locking stud nuts and gaskets at the head connection more often.
But the rest of the bike won't care one way or the other..........
"just sounds like a heap to me... proally needs all new rubber and all kinds of other stuff... i can see having another $3000 into this thing real fast and still needing more..."
Best advice ever! "oil leak in the underside’s rear drain hole"= engine or gearbox seal leak. "+ slight leak in the front master, the ABS light stays on and my biggest concern a cracked header pipe at the collector. It is a hairline crack that goes around the pipe (lower left side looking to the rear). I could not hear any additional exhaust noise or any rattling due to the crack." : Front master cylinder fix can be expensive,ABS faults may or may not be an easy/expensive/hard fix.Weld/braze fix to exhaust success hardto predict.Good luck,but personally I would check for better examples before buying this one!
Look for another, not worth it
I'll go against the flow here... Seeing I enjoy wrenching and building almost as much as riding...
K1100 Exhaust can be had on ebay for 150-175 USD.
And I've gotta do a rear M/C on my K75 this winter, and a front tire. Stuff happens. I personally don't feel buying a (minor) project bike is a deal breaker, as long as it's all considered in the price and you have both eyes wide open. I'd also say that everyone that is looking at any bikes with substantial miles or age would quite honestly expect to have to put tires on (at least you get to pick your brand and model).
You could end up with a good looking good running bike for under $2500 at the end of the shopping list. YMMV... Just sayin, think it through so there's no regrets if you walk away.
-mike
Forgot to add, my biggest concern is where the final drive leak is coming from. Could be the drain plug gasket got re-used one too many times (or not).
gotta open up the gear box for that oil leak... gonna have to do the engine and gear box seals and clutch o ring... at 70k it makes sense to do the clutch at the same time... throw in full spline lube and misc... parts alone for just this will be close to a thou...
Seems I misread the original post (away for a long weekend, only have my iPhone )
Trans leak, not final drive. I'll defer to Johnnie on that one, the voice of experience speaks ...
