TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: redtank on August 14, 2015, 05:39:02 PM
Title: Honda 60 moly paste problem
Post by: redtank on August 14, 2015, 05:39:02 PM
Hello,
So I wanted to lube my K75's drive shaft spines, so I get on Amazon and order Honda 60 moly past, being a Prime member I get it in 2 days, free shipping. So after receiving box I open only to find a small tube of M-77 assembly lube, so looking that up on line I find it's used on brake caliper shims when doing a brake job. I return M-77 and reorder.....next box, same thing, repeat one more time....same thing. Amazon is tired of sending me what I didn't order so all is returned. Now I look up Honda paste on eBay and vendors advertising it are selling M-77 paste as an updated item replacing 60 moly..... Anyone else running into this? I ended up lubing splines with Marine Moly past (comes in can with blue label).
Last question: what is best lube for clutch splines? My bike shifts easily, but is clunky (1st to 2nd is worst, down shifting lower gears noisy).
Thanks,
Cris
Title: Re: Honda 60 moly paste problem
Post by: rbm on August 14, 2015, 05:57:28 PM
Honda has stopped producing Moly 60 so Amazon is fulfilling orders with a lubricant that is nearly equivalent (it's stated on the Amazon page for M77 as being a replacement for Honda Moly 60).  Another lubricant that is recommended for splines is Guard Dog 525 (http://www.beemerboneyard.com/gdmoly2oz.html) available from Beemer Boneyard.  I've read about one K-bike owner who has used assembly paste to lubricate splines but I'm not sure what the long term outcome would be.  You're looking for high moly content lubricant, >60%.
Post by: Scott_ on August 14, 2015, 07:47:43 PM
You might check with some local Honda dealers and see if any have any stock left of the moly 60.
Post by: TimTyler on August 14, 2015, 08:32:40 PM
I'm still using the same tube of Castrol Optimol Paste TA (http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/104BC52BC4CE1D06802577960030186B/$File/453856_XI_en.pdf) that the BMW dealer recommended in 2011.
Post by: jay1622 on August 16, 2015, 09:15:59 PM
For those of you looking for the Castrol product, a British website has it for an excellent price shipped for under $25.
https://www.motobins.co.uk
Search for part number 95815  and determine if that is what you're looking for.
Post by: Motorhobo on August 17, 2015, 10:25:08 PM
+1 Guard Dog -- I have both it and the Honda Moly 60 and end up using the Honda Moly for everything but the gear splines -- GD is considerably tackier and seems like it would stick better.
Post by: herseyb on August 17, 2015, 11:34:01 PM
Dang, is the M77 no bueno?  I took the word of the part guy at the honda dealer that it was an improved replacement when I lubed my rear splines after getting my bike.
Post by: rbm on August 18, 2015, 12:00:12 AM
The MSDS for Molykote-M77 (http://www1.dowcorning.com/applications/search/products/details.aspx?prod=01005103&type=PROD&dsctry=USA) states:
Molybdenum Sulfide: 50% - 70%
Dimethyl, Phenylmethyl siloxane, trimethyl-terminated: 20% - 30%
12-Hydroxy lithium Stearate: 1% - 5%
Looks like the moly content is >60% so it should be good to go.
Post by: herseyb on August 18, 2015, 10:25:23 AM
sweet, I still have most of the tube.  Downshifting is getting a little stiffer than when I first had the bike, so I'm thinking it might be time to do the rest of the splines soon.  I can inspect the rear when I do, although I was hoping to hold out till winter.  I've only brought it from 15K to 18K, but it had sat outside for a while unused...
Post by: Red on August 19, 2015, 08:45:55 AM
+1 Guard Dog - utilizing Guard Dog on both of my K bikes. I had switched from a combination 50% Honda 60 Moly and 50% Wurther mix.  :popcorm
Post by: Markkeller on August 21, 2015, 08:03:09 PM
+1 on Guard Dog. I lubed output shaft on 1992 K75 at 19k miles. (1st time) using factory recommended Starburags NB30. 6k miles later in I go again due to difficult down shifts and caution. Starburags was nearly undectable. I think it had passed its shelf life when sold to me.
Guard Dog was sticky and slippery. After buttoning up, I second guessed applied amount. May have been slightly generous. Lubed the shaft and the clutch carrier. So far so good. Clutch not slipping and down shifts anytime I choose😊.
I love my K75.
