TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: redtank on August 08, 2015, 01:42:41 PM
Title: Oil Filter Cover Seal
Post by: redtank on August 08, 2015, 01:42:41 PM
I tried searching for information regarding the seal needed when changing engine oil filters on a K75, but didn't have any luck. My K75 is leaking oil from the round cover that has to be removed when changing the filter. Can someone point me in direction for the seal information, as I'm going to have to replace mine.
Thank you,
Cris
Title: Re: Oil Filter Cover Seal
Post by: RobP on August 08, 2015, 02:07:29 PM
There is an 88 x 3 o-ring that is often supplied with an oil filter kit.
11 13 1 460 425     - but double-check the part number for your specific year
Post by: Chaos on August 08, 2015, 03:32:08 PM
Beemerboneyard has a kit with the O-ring and some crush washers for $5   http://www.beemerboneyard.com/7119963300.html
Post by: johnny on August 08, 2015, 04:35:20 PM
those bonerbeemyard ones are the ones i use... no problems noted at this point... although im thinking all it really needs is more no corn ethyl and more oil and less filters...
Post by: redtank on August 08, 2015, 11:27:47 PM
Thank you all for replying.....will get the kit
