TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: darthbane71 on August 05, 2015, 09:55:42 AM
Title: No start after spark plugs?
Post by: darthbane71 on August 05, 2015, 09:55:42 AM
I went to change the plugs on the K75 I just picked up, and found out in addition to being old they were slightly fouled. Also, they were about .9mm, so pretty far out of the manual's stated limit of .8mm. I replaced the plugs and put the plug wires back on, went to start the bike and nothing. So then we put the old plugs back in......still nothing. Now there is no condition we can get it to start, old plugs, new plugs, nothing......
Also, when we have the choke on (1/2 choke or full choke) or the throttle opened, after a few revolutions the starter (I think, it's hard to tell but I think that's where it's coming from, will make a loud metallic clunking noise. This is only when the choke is on or the throttle is twisted.
Any ideas? The motor has compression, fuel, and spark so I'm kind of at a loss for why it's acting the way it is.
Title: Re: No start after spark plugs?
Post by: TimTyler on August 05, 2015, 11:30:50 AM
Did you put the wires on in the proper order?  Plug #1 connects to coil #1. Same with #2 and #3.
Post by: darthbane71 on August 05, 2015, 12:17:35 PM
Yes, I double checked the coils
Post by: TimTyler on August 05, 2015, 12:27:54 PM
Dumb question, but are the ignition coils firmly attached to the spark plugs? They snap on.
Which plugs are you using?
Post by: darthbane71 on August 05, 2015, 12:29:10 PM
Yes they are firmly attached. Using NGK D7EA.
Even tried switching back to the old plugs and nothing changes
Post by: darthbane71 on August 06, 2015, 11:23:26 PM
New development. Left the plugs out all night and cleaned the injectors and now she sputters and coughs but when it gets close to running (with the choke on or the throttle open) it makes the loud clacking noise from the area of the starter and then dies.
Post by: TimTyler on August 07, 2015, 02:52:24 AM
Record the starting sounds and upload to youtube.
Post by: ts888 on August 07, 2015, 02:55:59 PM
Have you tried cranking it with the plugs out?  It almost sounds like it's hydro-locking a bit, like there's fuel flooding in the cylinders.
Post by: darthbane71 on August 09, 2015, 03:05:29 AM
https://youtu.be/soxE5wQzjAw
This is what it is doing, hard to hear exactly what it's doing but every time the choke is on or the throttle is open it makes a loud metallic clack
Post by: TimTyler on August 09, 2015, 04:25:33 AM
That sounds weird. Like the throttle body butterflies are snapping closed.
Post by: johnny on August 09, 2015, 08:03:57 AM
greetings darthbane71...
in another thread you said the moto has been sitting for 2 years...
did it run... run good... as in riding it... before you replaced the plugs...
also... what all has been done to this moto previous to you and by you...
Post by: The Mighty Gryphon on August 09, 2015, 08:13:13 AM
Sounds like f'd ignition timing.
Post by: TimTyler on August 09, 2015, 11:00:48 AM
Yeah - Take your T-shaped HES cover off on the front of the engine and see if your HES looks like this:
Post by: darthbane71 on August 09, 2015, 01:29:10 PM
Not much has been done to it to my knowledge. I didnt' ride it as the brakes needed work. However, It did run before we changed plugs.
I'll take a look at the timing today
Post by: bizzaro on August 09, 2015, 03:32:49 PM
Not sure if this has anything to do with it, but. On my 94K1100lt the plug leads are designed for the bulb type tip connection.  The NGK plugs are screw top, and they don't come with the handy screw on tip(bulb).  Bosch for my bike are bulb type connection??? just a thought.  The guy at NAPA was nice enough to rustle me up some screw on tips(bulb).  And the connectors don't just snap on. It takes a good bit of force to seat em.
Post by: darthbane71 on August 09, 2015, 07:36:03 PM
UPDATE
I'm stupid. The plug wires WERE on wrong. it runs like a top now.
Sorry! Thanks for the help guys
