TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: MonkeyMcBean on July 06, 2015, 01:10:52 AM
So, I was working on my bike. Replacing 25 year old fuel lines, ethanol clogged fuel filters... you know the drill.
I turned the bike on to ensure the fuel pump was working before putting it all back together. I smelled and saw smoke coming up from under the temporary location of the tank. The culprit was still hot after I killed everything, removed the keys and moved the tank again. What circuit is this? Anyone know? Looks like it heads toward the front instrument panel. What's going on?
(http://i.imgur.com/ZbhkTbB.jpg)
(http://i.imgur.com/ZRqrQ2Q.jpg)
Ok, traced them. It's the heated grips. I broke them a while back. Will it mess anything up if I just disconnect this?
You can disconnect the heated grips without messing anything up.
