TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Nantucket_Red on July 02, 2015, 05:39:39 PM
Title: Oil filter bolts hogged out.
Post by: Nantucket_Red on July 02, 2015, 05:39:39 PM
So the oil filter allan heads are stripped out. About to cut the heads off and order bolts. What is a better idea.... I'm sure someone has dealt with this before.
Title: Re: Oil filter bolts hogged out.
Post by: Scott_ on July 02, 2015, 06:14:33 PM
Well, to be able to work on it the easiest, remove the entire pan bottom then you can work on a bench without laying under the bike.
You could also drill them out with left handed drill bits/extractors, but yes you will need some new ones.
A good local hardware store may have some without them having to come from BMW.
M6x20mm is the screw size for the filter cover, the pan mounting screws are M6x25mm if you want to take one of them to the local store for sizing....
Post by: Chaos on July 02, 2015, 06:33:08 PM
you could also use a dremal to cut a slot in them
Post by: Nantucket_Red on July 02, 2015, 06:51:43 PM
I like that idea chaos. Gonna try it. If all else fails I'll drop the pan and go from there. Is there a gasket or is it goo I need to use for it?
Post by: Scott_ on July 02, 2015, 08:06:53 PM
No gasket.
I used RTV blue the last time I had one off.
Post by: pallum on July 03, 2015, 02:01:56 AM
No gasket.
RTV is a necessity. Blue or Black from Permatex both work well  :2thumbup:
Post by: drut on July 03, 2015, 06:59:15 AM
Had some success with removing rounded allen bolts by hammering in slightly bigger torx bit.
Post by: Nantucket_Red on July 03, 2015, 06:53:39 PM
Okay so I won't the battle. Replaced the hardware as well. Before I go and dump m oil in how full should the sight glass after the bike has been run up to operating temperature and then shut off? Should it be full or at the dot in the sight glass.
Post by: Chaos on July 03, 2015, 07:08:03 PM
anywhere between the top and bottom is good.  dot is ideal.
Post by: Nantucket_Red on July 03, 2015, 07:51:39 PM
Awesome. Bike runs again. Thanks for all the help guys.
Post by: kryder on July 03, 2015, 07:58:47 PM
This is the way I've done it in the past. After cutting a slot with a Dremel I use a big flat head and remove, then replace with new. The last K I bought had them overtightened.
