TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: MonkeyMcBean on June 28, 2015, 12:42:46 PM
Title: fork wobble
Post by: MonkeyMcBean on June 28, 2015, 12:42:46 PM
My front fork used to always track smooth and straight. Suddenly, it has started to wobble under braking and deceleration. I have no idea what is happening. Does anybody have any ideas? Thank you!
Title: Re: fork wobble
Post by: johnny on June 28, 2015, 01:32:54 PM
greetings monkeymcbean...
generally wabbles are from tiors... front or rear... or bent wheels...
butts wabble under front braking is generally warped rotor or whack bobbins...
butts i donts thinks you gotts bobbins (http://www.motobrick.com/index.php/topic,1132.msg10261.html#msg10261) on that seven fitty... so i would be looking for warped rotors 1st...
Post by: MonkeyMcBean on June 28, 2015, 01:35:26 PM
The wobble isn't due to braking, because it happens under non-braking too. Maybe I should gethe my wheels re balanced.
Post by: johnny on June 28, 2015, 01:40:27 PM
awech1tt... i musta miss interpreted "wabble under braking" as meaning when you braked you gotts a wabble...
so... if its not wabbling under breaking its proally not warped rotors...
only on deceleration... if feeling it in the forks it could be final drive pillion bearing going whack...
Post by: rbm on June 28, 2015, 02:04:57 PM
could be excessive freeplay in the headstock.  Have you checked?
Post by: MonkeyMcBean on June 28, 2015, 04:51:05 PM
Yeah, my bad. I should have been more clear.
