TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Nantucket_Red on June 27, 2015, 07:19:29 PM
Title: Replacement rotors and pads.
Post by: Nantucket_Red on June 27, 2015, 07:19:29 PM
What would you recommend for rotors and pads that won't break the bank? Also some sites prompt me for abs and non abs models for my 87 k100rt. Not sure how to tell.
Title: Re: Replacement rotors and pads.
Post by: rbm on June 27, 2015, 07:30:31 PM
You would have monstrously large modulators on either side of the rear footpeg plates with the letter "ABS" emblazoned on them.  If you don't have these, you have non-abs brakes.
Post by: johnny on June 27, 2015, 07:31:11 PM
greetings nantucket_red...
new rotors... you need... or you just want...
as for pads... i use ebc organic... (http://www.motobrick.com/index.php/topic,4676.0.html)
Post by: Nantucket_Red on June 27, 2015, 08:10:17 PM
Not sure if I need rotors yet, there isn't any grooves ground into them or warping. Just seeing what my options are. I'll look into those pads you listed
Post by: Scott_ on June 27, 2015, 08:36:35 PM
Stamped on the rotor will be the minimum safe thickness. Only way to know is to measure it with a micrometer.
I purchased a new rear rotor from BeemerBoneyard.
Post by: Chaos on June 27, 2015, 09:37:21 PM
Rotors cost more than I can justify for the old girl.  I'm gonna wear them down 'till the pads touch each other.
Post by: Nantucket_Red on June 27, 2015, 09:53:44 PM
Too true from what I've seen. I'm going to give those pads Johnny suggested a try.  :2thumbup:
Post by: Scott_ on June 27, 2015, 10:25:34 PM
The rotors are just as much a "consumable" component as the rotor bobins, pads, and clutch. They do wear to the point that they will need replaced. The more miles you have, city stop and go traffic, or mountain roads, the more likely they will need replaced sooner than later.
I put a set of used rotors on the front @105K miles and a new one on the rear of my '95 at 108K miles.
Some bike breakers will sell rotors separate from the wheels, some don't.
Post by: Chaos on June 27, 2015, 10:34:01 PM
These look like they might still have some like left in them.  Could probably get them cheap :yes
http://www.motobrick.com/index.php/topic,7016.msg48158.html#msg48158
Post by: MonkeyMcBean on June 27, 2015, 10:37:51 PM
Her body isn't even cold yet, you vulture! :yes
Post by: Nantucket_Red on June 27, 2015, 11:06:31 PM
I read that thread a few days ago. Damn near cried. That's what happened to my old 240SX.
