TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Nantucket_Red on June 21, 2015, 08:13:26 PM
Before:
https://www.youtube.com/watch?v=zSM1X9ahbmM
After:
https://www.youtube.com/watch?v=s66i42RZw6M
There is still a little bit of return lag when the bike is on. Could it be the return spring on the linkage? I haven't check that yet as it is raining currently. Either way it is heaps better now.
(why I was trying to turn the grip the wrong way is beyond me...)
Since you live on the Cape, do you have a boat with an outboard? I run one on a workboat and still will occasionally try to turn the throttle in the direction of a bike throttle when I'm running right handed.
Your throttle lock is disengaged, right?
That dongle with the spring? Should be, but I'll double check it.
Used to, old habits die hard lol
Removed it completely. No change, there is no snap back from minor blips of the throttle.
I'd remove the throttle cable from the throttle bodies and the throttle grip. Then I'd feel for resistance in the grip, the cable and the throttle bodies independently. I bet you need a new cable. If the cable is original it's not a bad idea to replace it anyway. Keep the old one in your cowl as a spare.
Seeing as I haven't tried that, I might as well.
You may need a new cable, but step one is to remove the throttle cam cover by the twistgrip, remove your bar end weight, take the twistgrip off and clean out all of the old gunky grease in the throttle cam and gears, inside the twistgrip tube, and on the handlebar. Clean everything well, reassemble with fresh grease and see how it feels. I have yet to buy an old BMW that has ever had any attention paid to this rather unique setup and all of them feel gross and draggy.
I need to do that to both of my K's, but the damn heater wiring scares me.
Anybody just replaced the throttle side perch with something from another bike? Frankly I'm not a fan of the original gear on gear drive design.
I take it you're referring to the K100 throttle. Throttle from a K1100 will fit with very little fuss, on a K100. It is more like a Japanese bike with a direct throttle cable attachment, and no gearing inside the throttle housing. If you mean from a Japanese motorcycle, then yes others have done that. (http://www.motobrick.com/index.php/topic,6775.msg46585.html#msg46585)
I've never had any problem with my cable or the throttle mechanism, but I clean it once a year and relubricate it with lithium spray grease. I also use TRI FLOW PTFE spray lube on all the cables 2-3 times a year. BMW does not recommend lubricating cables, but I've had the bike 17 years & done 150,000 K's. TRI FLOW is available from bicycle shops.
Thanks. I'll start looking at the K1100 option. Throttle tube gearing is damaged and new is NLA.
did you pull the grip off the handlebar and clean that up? that's where mine was hanging up, lots of crud builds up in there.
It's listed as available at MAXBMW. Section 32, Diagram #32_1967 in K100RT, buddymack. Part #8 and maybe you'll need #7, too. http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51754&rnd=07012015
If the throttle tube itself is damaged, that looks like #24.
Haven't had any luck finding a K11 throttle assembly. Any suggestions on where to look?
Well, you can always repair what you've got anyway.
Found a used stock throttle tube, cleaned it thoroughly, filed the gear end removing any burrs, and installed it. For the first time ever, the throttle springs closed when released! I can live with that!
Now that's what we're talking about!
Took my bike out for a run on Saturday and was surprised by the effort required and to a certain extent found it tiring on that hand.
Also the free play in the cable needs taken up as it is not conducive to smooth riding in traffic. I suppose that on a 30 year old machine you can expect some crudding up and it clearly wasn't a priority to the previous owner .
Will have a look at the manual but are there any tips
Remove the cutoff switch plate by unfastening the small screw at the bottom. Remove the screw from the top of flat throttle gear housing to the right of the combo switch. Clean out the old grease, add fresh lithium grease or silicone spray. Align the mark on the gear with the mark on the assembly. Reassemble everything then be sure the flange on the grip isn't rubbing the house and your throttle screw on the back side of the throttle to the right of the switch/throttle gear assembly—if your bike has one—isn't engaging the throttle.
If you want to get the chain and gear out to do a good cleaning you will need to move the front brake master cylinder.
There are two fillister head screws that hold it on to the perch. They come in from the side facing the instrument cluster, one in the front under the reservoir, and the other near the wire for the brake switch. Take them out and lift the reservoir and you can get all the throttle stuff out to give it it's first good clean in 25 years.
