TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: JonoK75 on June 21, 2015, 04:58:55 AM
Hi all, I'm going the KBike brains trusty can help me out. . Started the bike. .no problems. . Went for a good 1hr ride parked on side stand and left out for a couple of hours.. tried to start the bike and got nothing. .. checked kill switch. . Bike in start position... all the usual lights on the dash on. .pulled clutch and still nothing. I ended up bump starting the bike to get it home and have read through a bunch of forums to narrow down the issue but have hit a dead end. . So far I have checked all fuses, battery fully charged, pulled apart the starter motor (cleaned bushes) all seems ok, checked starter relay (connections haven't fused. .looks ok) and checked plugs. .when I try to start the bike. . I can't hear the fuel pump. . Could that be the issue? Also I can't hear the click of the relay.. any advice would be great the next step is to pass it onto the pro's.. which would more than likely cost a bomb! ! Thanks
Check the starter signal circuit:
The connector for the RHS switch assy you find on the right side under the tank.
With ignition on you should have 12V+ at the black/green wire when the neutral lamp is lit or the clutch is pulled.
When you push the starter button you should get 12V+ at the black/yellow wire.
If the previous is OK, check that the signal reaches the starter relay...12V+ at the black/yellow wire.
If also this is OK, check that you have ground signal to the starter relay coil at the brown/red wire.
If no ground, the problem is the ignition ICU at the headstock which grounds the starter relay coil,
but also check in that ende of the wire.
Thanks Inge.K! You're below suggestions helped me find the issue. . It ended up being the clutch switch.. I bridged the connection under the tank and all sorted. . My only other question is. . Now that I've bridged the connection will this cause any issues down the track? ? Thanks Jono
