MOTOBRICK.COM => The MBdotCOM Community Center => Topic started by: subforry on June 16, 2015, 12:21:02 PM
Title: tracking - look ma no hands
Post by: subforry on June 16, 2015, 12:21:02 PM
Hi all,
When I am riding on an arrow straight road with the very slight crown and set the cruise control, my K1100 will drift to the left if I take my hands off the bars.  Is this typical, caused by the crown, or is there an alignment I should check?
Thanks
Title: Re: tracking - look ma no hands
Post by: TimTyler on June 16, 2015, 02:10:16 PM
Here in the US, mine drifts slightly to the right. I can keep it straight by repositioning my body.
I've tried aligning my forks, replacing wheel bearings, steering bearings and fresh tires.
Post by: drut on June 16, 2015, 02:46:22 PM
"When I am riding on an arrow straight road with the very slight crown and set the cruise control, my K1100 will drift to the left if I take my hands off the bars.  Is this typical, caused by the crown, or is there an alignment I should check?"
My 16v K100RS does the same,drift/pull to left is only slight but noticeable.Originally thought it might be tires but just the same with new set.
Post by: Chaos on June 18, 2015, 09:47:45 PM
The bikes are not balanced with the crank and swingarm on the right side.  And on some K's the rear wheel is offset a couple mm.  Nothing to worry about.
Post by: ts888 on August 04, 2015, 01:14:04 AM
I can't decide if this was a conscious or unconscious zinger.    :giggles
Post by: beemuker on August 04, 2015, 09:31:03 AM
mine too. I just asked this in another post and they all seem to do it.
