TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Bokobob on June 08, 2015, 07:13:57 PM
Title: Tough work but succeeded
Post by: Bokobob on June 08, 2015, 07:13:57 PM
Getting the battery charged on the K75 and then removed to see if I could find a replacement was next to as difficult as a frame-off restoration of an old car...Sooooo complicated....could not find a new one but found the existing Yausa brand battery was half empty on fluid so added distilled water and Autozone threw a quick charge on it and said it was good so I shoehorned it back into the bike in 90 minutes and 700 cuss words later....Geeminy  what a project.  Took a good ride, first one in three weeks on the flying brick..
Just wanting to vent.
Title: Re: Tough work but succeeded
Post by: johnny on June 08, 2015, 07:39:43 PM
id rather to do a valve adjustment than replace the battery...
Post by: TimTyler on June 08, 2015, 07:59:24 PM
Betcha the next time you do it will take you 15 minutes.
Post by: Bokobob on June 09, 2015, 06:07:51 AM
Yep, I ain't looking forward to doing it again, that's for sure....however, while I don't think I could ever do it in 15 minutes, I would imagine it would be somewhat easier..I say "would be" rather than "will be" because I have the hunch that I would be wise to bow to Father Time (I hit 80 next May) and pass this high seater along to some other enthusiast and ride my low-seat Magna  cruiser.  I had a noticeable amount of awkwardness on my ride yesterday due to the height of the bike versus my 29" inseam.  Will take a few more rides before deciding..  Possibly am just needing to get used to it again after three weeks of not riding it at all.
Post by: The Mighty Gryphon on June 09, 2015, 10:18:15 AM
Don't know how old your battery is, but I replaced the Yuasa that came with my K75 with a Scorpion AGM battery.  The Scorpion slips right in.
http://www.batterystuff.com/powersports-batteries/sYT51913-22.html
It's only 255 CCA, but in over a year and 15.000 miles of using this battery it has not failed to start the engine, even in the winter when the bike was at 10 degrees F and lower.
Pushing 80!  You're an inspiration to me at 66 that I will be able to ride a few more years.
Post by: K75RT Keith on June 09, 2015, 10:37:10 AM
Went the AGM route too.  nice to be able to tilt the battery any direction without acid dripping out.  I can now pull and replace the battery without removing the ECU compartment.
Post by: Bokobob on June 09, 2015, 01:12:31 PM
I considered a smaller battery that was 325 rated vs the one installed which is 400 rated.  I am glad to hear the smaller one is working for you.
I have decided to sell the bike..I took another ride today and it was somewhat unsettling due to high seat.
$2000 cash, firm...well maintained.  Has new OEM crash bars, pegs, both splines lubed last summer (dealer receipts), Pirelli tires late 2014, odometer overhauled 2015 and reset to approximate miles (was 33K and I had them set it to 40K), new front master cylinder and new throttle cable last fall...Big Windshield.  both touring and sport handlebars (tourings are installed now).  Corbin seat and rider or passenger adjustable backrest, owners manual, Haynes and Clymer manuals, extra parts, etc.  Making $100 allowance for replacement of lost right side battery cover.  Thus firm price adjusted to $1900.  Very decent paint for the most part.
Post by: mr_10brook on June 10, 2015, 05:31:07 PM
I use 20LB-S  or AGM equivalent battery in my K's.
About the same cranking amps and smaller dimensions.  It makes a very easy swap.
