TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: kenray on June 06, 2015, 10:36:58 AM
What is the difference between a k75/100 non abs front brake cylinder vs an abs front brake master cylinder. Thanks for any info. Ken in Katry Tx.
I think the piston in the ABS version is a little bigger.
The ABS master have a adjustement screw at the lever, and a harder material at the lever end of the piston.
I think I'm wrong. I just checked the fiche and it appears all the rear pistons are 12mm and all the front pistons are 13mm.
Rear master did change from 13mm to 12mm during -88.
