TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: rogan on May 26, 2015, 01:59:17 PM
Title: 1985 K100 RT Instrument Cluster Removal
Post by: rogan on May 26, 2015, 01:59:17 PM
Newbie here, I have a 1985 K100 RS with a full RT fairing. I have several instrument cluster warning lights out and would like to test/replace them.  Looking at the Clymers manual and the bike, it appears that I will have to remove most if not all of the fairing to get at the back of the instrument cluster to remove it.  Just removing the windshield doesn't appear to provide enough access, and the windshield screws have backing nuts that are not readily accessible anyway without digging into the fairing  Is this correct?  I have looked at some of the topics here related to K75 fairing removal, and K100 instrument cluster removal, but it seems mine will be more involved. Any sage advice?
Thanks.
Rogan
Title: Re: 1985 K100 RT Instrument Cluster Removal
Post by: rogan on May 26, 2015, 03:55:09 PM
OK, the good news is that I was able to get at the back of the instrument cluster after removing the lower leg shield and storage pockets.
Couple of pieces of bad news though.  A previous owner seems to have replaced a missing (I'm guessing)backing plate in the lower center of the back of the housing with a thin piece of wood with epoxy dribbled on it, and screwed it into the housing, so it covers most of the opening, but certainly isn't dust or watertight.
Also the only bulb that actually seems to be burned out is a green coated general illumination bulb in one corner.  The oil pressure light and the low fuel lights that I believe are supposed to light when the ignition key is first turned to the on position before starting test good, but do not work on the bike.  I'll search for other threads, but I assume this means a bad connection, sensor, or other component somewhere else in those circuits.  Any tips here would be appreciated.
Thanks.
Post by: billday on May 26, 2015, 09:48:00 PM
The low fuel lights do not "test" when you turn on the key.
As for the bad bulb: The bulb gets wedged into a square opening, and on either side of the opening is a flap of sheet-like copper conductive material. Make sure that flap is draped over the opening so it can make contact with the bulb holder. Lots of times it gets folded underneath its self.
Post by: rogan on May 27, 2015, 01:10:37 AM
My rider's manual says on p. 12 that the oil pressure, battery charge, choke, rear light monitor, neutral, and 5 liter fuel warning/telltale lights are supposed to come on when the ignition switch is in position 2 before starting.  My bike has two fuel warning lamps, for 7 liters and 4 liters, neither of which have come on with the ignition switch. So you have this two fuel lamp setup, and the two lights do come on in sequence as the fuel drops, even though they don't light up before starting?  That would be great (I haven't run the fuel down yet).
How about the coolant temp light? Page 12 doesn't say it should come on with the ignition switch, but page 34 says to check that the coolant temp warning light is operating correctly, so I was thinking that might come on before starting also. If not, any idea what the procedure would be for checking it?
Perhaps the only one that isn't working is the oil pressure light circuit.
All the brass contact flaps on the circuit board look good.
Thanks again.
Post by: rbm on May 27, 2015, 07:12:46 AM
Since you have the cluster off, take the bulb out and test it with a 12V battery.  That will confirm the bulb as being good or bad. If you want to test the circuit that activates the bulb, ground Pin #A3 on the temperature relay in the relay box under the tank (after first removing the relay from its socket).  That should illuminate the bulb on the dash.
Quote
Thanks again.
The oil pressure light should come on with the key in position 2 because there will be no oil pressure in a motorcycle that is turned off.  Once the motor starts and the oil pressure builds up, the light should extinguish.  If yours is not coming on with the ignition, there is a problem with either the bulb or the oil pressure sensor, located in the water/oil pump.
Post by: rogan on May 27, 2015, 11:05:09 AM
Rbm, yes, I checked all the warning bulbs after removing them already and they were good, unfortunately. Thanks for the next steps for the coolant and oil pressure circuits.
Post by: rogan on June 09, 2015, 02:37:47 AM
Rbm, I tested the coolant temperature circuit as you suggested, and the dash light lit up, so that should be OK.  I planned to replace the oil pressure sending unit, since cleaning the contacts made no difference.  Before removing the sender I wanted to clean the crud from the area, and in doing so, I found one crack in the insulation on the wire coming from the sender near where it enters the engine.  I reconnected the wire and tried again, and this time I did get the light to come on with the ignition switch on, so hopefully it will keep working.
The remaining warning lights that aren't working are the 7L and 4L low fuel lights.  I've run it nearly to empty and neither lit up.  I may end up relying on the tripmeter once I get a better idea of the gas mileage. It looks like I need to remove the gas tank to be able to access the wires and connections that run along the frame from the fuel sensor.  Any suggestions that anyone may have about other tests to run on the sensor or its circuit would be appreciated.  I understand that there is a separate printed circuit board inside the cluster for the fuel lamps, but I wasn't able to see any physical flaws when I had the cluster apart before.
Thanks again.
Post by: rogan on June 16, 2015, 03:23:55 PM
I'm back looking at my problem with no low fuel light warning lights. One question I have is about the pin connectors on the back of the instrument cluster.  I'm assuming for now that the cluster is the original for my 1985 K100RS.  Is there a simple diagram of the connector pins on the cluster and which circuits they are on?  I have a schematic in the Clymers manual, but don't understand it well enough to translate it to the pin positions. For example, when someone here refers to pin 7 or pin 6, which of the two connector banks on the instrument cluster is meant, and is pin 1 at the top or bottom of the plug?
Also, each connector bank on the cluster has 11 pins, 4 at the bottom, then a gap, and 7 more up to the top.  However, the bank on the left as seen with the cluster removed and looking at its back has a small hole in the plastic base as if there may have been another pin there that broke off at one time. The wire plug-in connector for that side has 12 open slots, while the one on the right side has a plastic plug in the slot fifth from the bottom, indicating that the right side plug never had a 12th pin, but the left side may have. The wire going into the back of the socket correlating to the "missing" pin is brown/black, which is the color of one of the 4 wires coming out of the undertank connectors wired to the fuel sender after it exits the tank.
Can anyone provide some information on these questions?  I've tried to attach a photo of the pins, but it may be difficult to see the difference in the "missing" pin on the left side.
Thanks much.
Post by: rbm on June 16, 2015, 10:16:16 PM
This is the pinout on the back of the instrument cluster
(http://hrsbstaff.ednet.ns.ca/bvogel/K100/download/electrical/Instrument%20cluster%20plug.jpg)
Your blank pins correspond to pins 8 and 20.  Since 8 is missing, the cluster is probably not one made for the pre-85 with the earlier fuel level sender and therefore is probably not the original gauge cluster for your bike.  The gauge will not be equipped with the circuit needed to make the sender function nor equipped with the yellow 7L fuel level indicator.  The  gauge will have the 4L indicator but it will not function with your fuel sender.
Post by: rogan on June 17, 2015, 03:17:25 AM
Rbm, thanks once again for your knowledge, and the plug pin arrangement list.  Exactly what I was looking for.  It's quite possible this is not the original cluster and is incompatible with the sender, though it does have both the 7L and 4L labels on the face of the warning lights. I suppose any of the various fuel warning components could have been replaced at some point with incompatible parts, or that the #8 pin was indeed broken off at some point.
Thanks once again for your help.
Post by: rogan on June 19, 2015, 09:29:33 PM
Still looking at the instrument cluster innards to see if there is anything to explain the lack of low fuel warning lights, beyond what we have already discussed.  I opened up the cluster housing again, and noticed that there is a copper circular contact in the upper left hand corner of the blue plastic film (as you are looking at it from the back) that is not attached to another component.  There is also a circuit board in this upper left corner. I read elsewhere that this board is part of the fuel warning system though I don't know if that is correct.
Most of the copper contacts on the blue film seem to be attached through the plastic to the underside of the board with what looks to me like a rivet, or tiny spot weld.  This particular contact isn't attached to anything, though there is some kind of component underneath.  I've attached a grainy photo to illustrate. The contact at the top of the photo is unattached, the one below it has one of the "rivets" connecting it to another part.
Does anyone know if this contact should be electrically connected to the component under the board, like the one just below it is?  Is this in fact part of the fuel warning system?
Thanks for any help.
Post by: Inge K. on June 21, 2015, 04:45:44 AM
You have the correct fuel level warning PCB (also the speedo and tacho) for your model.
But the center plastic part with the blue conductive film is from a -86 or later.
But still the 4L warning lamp should function, tho.
Post by: rogan on June 22, 2015, 01:37:51 PM
That's very interesting.  I would have thought that it would be difficult to change out the blue plastic film printed circuits and all its connections.
I used a piece of solid copper wire and soldered it to the copper contact on the blue film where the #8 pin should be, to see if that would make a difference on the 7L warning light, before I got Inge's last message.  May not have gotten a great joint because I didn't want to melt the plastic film, but in any case the 7L light didn't light up after I plugged in the multipin connectors.  I suppose if the blue film is from the '86 and later bikes that didn't have the 7L circuit, then it wouldn't work anyway.
I guess one of the questions now is whether the blue film I have supports only the 5L warning light, and whether I have an original sending unit in the tank that is not compatible with the 5L setup, or is defective.
Thanks Inge.
Post by: Inge K. on June 22, 2015, 04:56:56 PM
The white plastic part with bulb holders, blue conductive film and connecting pins is one part.
The later version missing the three connecting pins for the 7L warning lamp.
I used a piece of solid copper wire and soldered it to the copper contact on the blue film where the #8 pin should be, , but in any case the 7L light didn't light up after I plugged in the multipin connectors.
You also need to connect the input and output contacts at the pcb to make the circuit complete.
But the 7L warning lamp is useless anyway....starts to flash above half tank.
If you have the connector for the sender and pump in the left front corner on the underside of the tank
it's compatible with the pcb inside the instrument......the later tank have also different mountings.
Post by: rogan on June 22, 2015, 07:14:29 PM
Ok, I'll stop obsessing about the 7L light.  Thanks for the additional insights, Inge. Would be nice to have the 4L light though.
[/quote]
[/quote]
The connector is in the left front corner under the tank. Four wires exit the tank, go through two connectors of two wires each, and then recombine into a bundle that goes forward toward the cluster.  The wires coming out of the tank are: green/red and yellow/ green, which go into a black connector, and emerge as green/yellow and brown/white going forward; and black/white and tan(?), which go into the other connector and emerge as brown and brown/black going forward. I'm not sure if this was the stock setup or if it indicates something about which sender is in the tank.
Thanks.
Post by: rbm on June 22, 2015, 07:37:31 PM
Sounds like the fuel sending circuit has been modified. There should be a single round white 4-pin connector to hook up to the tank as in the photo below, not two 2-pin:
(http://i39.servimg.com/u/f39/18/98/28/51/photo_12.jpg)
The OEM wire colouring emerging from the tank should be:
Brown/Black  (T1): 7L thermistor
Brown/White  (T2): 4L thermistor
Green/White (15):  Fuel pump power +12V
Brown  (31):  Ground
Designations in brackets are the ISO pin numbering.
It could be the thermistors in the sending unit are not functioning, causing the lights not to work.  They should read 600 ohms between ground (probably your black/white) and each individual thermistor (probably your yellow/green and tan). I'm guessing here since the harness wiring is odd as well.
Post by: rogan on June 23, 2015, 12:17:14 PM
Rbm, thanks. Yes, I definitely have some ad hoc wiring.  I unwrapped the electrical tape around the wires between the tank and the black connectors.  In doing so, the connection to the four prong plug that exits the tank came apart, revealing four separate black slide-on connectors, kind of like a crimp-on connector, but not crimped. Connections weren't very clean, and evidently were held in place only by the tape wrap. The fuel pump has been working, so at least some of the connections were good. At this point I removed the tank, since I could see floating debris in the gas, and I wanted to clean it out and replace the fuel filter anyway.
I removed the large nut holding the sensor onto the tank, and pulled out a plastic covered cylinder, which I assume is the sensor, but it doesn't have a float like the others I've seen.  Maybe this is the original version that was changed on later models? Two wires enter the unit from the tank, one purple, one gray, which must come from the fuel pump.  There is an opening toward the bottom of the cylinder where you can see what wires enter the four prong plug. There are five wires: two gray, one purple, one reddish orange, and one dark brown.  The two gray wires look like they join to one of the four prongs.  I've attached some pictures, to give a general idea of the layout. Perhaps I could try to run the test you suggested on the prongs in the plug, though even those don't seem to jibe with the standard color wires. Is that a test I can run with the tank off and no power to the circuit?
The only white four prong connector like the one in your picture that I have found is in the relay box, and is not attached to a plug. The wires going into it are brown, green/purple, red/yellow, and green/brown. Don't know what the function of this would be.
Thanks again.
Post by: rogan on June 23, 2015, 02:04:59 PM
Rbm, I'm getting 600 ohms between the ground prong (which I'm assuming is the one the dark brown or black lead connects to in the sensing unit) and two of the other prongs--one with the two grays, and one with the purple wire.  I also found a cutaway photo of this sensor online that shows a red wire, so maybe I'm dealing with the original part.
Post by: rbm on June 23, 2015, 03:18:15 PM
Correct.  This version uses thermistors that get cooled by the fuel when immersed and heated when exposed to air.  The circuit board in the instrument cluster understands how to interpret these temperature differences and turns on/off lights on the dash.  The circuit is attached to this post.
Quote from: rogan
These would be the common connection between the thermistors which would be connected to ground.
Quote from: rogan
Yes, you can do that.
Quote from: rogan
Thanks again.
This is the optional alarm connector. Green/purple is actually green/gray.  Age does strange things to vinyl.  If you want, you can repurpose that connector if you feel you will never need the alarm function on the motorcycle.
If you are not already aware, a full colour schematic for the early RS/RT (https://drive.google.com/open?id=0B3UPbNZRyr1rR3dUOHBhQXp2LXM&authuser=0) can be found on my Google Drive.
Post by: rogan on June 23, 2015, 03:42:10 PM
Rbm, thanks again.  If I did the Ohm test correctly in my previous post, it seems like the sensor itself may be good. Inge says that my blue plastic circuit board is a later one that will not  work with the 7L light, but I'm wondering if I can get it to work with the 4L light.  I doubt I'd ever use the alarm connector, so I like the idea of being able to plug it in properly to the sensor prongs.  I'd have to be careful to wire the leads from the alarm connector to the downstream wires properly and label them so it the color scheme isn't so confusing.
Do you think it's feasible to get the 4L light to work in this fashion?
Thanks.
Post by: rbm on June 23, 2015, 06:12:20 PM
There are two sensors so make sure you test both.
I would not suggest trying to rewire the alarm connector.  Rather, clip the connector off with some leads remaining, long enough to splice into the existing harness wires.  You'll be splicing and soldering the connector to the harness wires, then covering them in shrinkwrap tubing to insulate them.  That means you'll need to positively identify the corresponding connections on the sensor assembly, so take your time doing that.
It shouldn't be hard to get the 4L light to work.  If it is going to work at all, once you connect the thermistor and ground, the light should illuminate (with battery power applied) because the thermistor will be in free air.  Take time to conduct these tests before buttoning up your work.
Post by: rogan on June 23, 2015, 11:08:09 PM
Quote
That's what I was asking in my post#17.  I got readings of about 500 ohms when I retested with a different meter from two of the prongs, the one with the double gray wire and the purple one, assuming the brown wire is the ground.  Is there something else to test?
I wasn't going to rewire the alarm, just use the connector. I may use Posi-lock connectors with shrink tubing instead of soldering, we'll see.
Quote
I'd certainly like to think so!
Thanks again.
Post by: rbm on June 24, 2015, 06:29:31 AM
Thermistor configuration inside the sender:
(https://lh3.googleusercontent.com/-bhLe1MYDMmo/VYqGU8u4XMI/AAAAAAAAGDw/ruCZAB6X1Vk/s800/1985%252520BMW%252520K100%252520fuel%252520sensor%252520cutaway.jpg)
And the associated schematic, showing the two thermistors T1 and T2:
(https://lh3.googleusercontent.com/-3_XOzC4DWkc/VYqIH7FXgFI/AAAAAAAAGD8/Z3GxHwuc33c/s400/early%252520fuel%252520sender.png)
Post by: rogan on June 24, 2015, 12:17:19 PM
Rbm, sorry, I think I need a simpler explanation.  My electrical knowledge is rudimentary at best.
Are both thermistors attached to (or part of ) the red wire that your arrows were pointing to on the cutaway photo?  I checked the resistance between the pin connected to the brown wire, and the pin connected to the red wire, and I got 1200 ohms.  If both thermistors are on that circuit, and each have 600 ohms resistance, then it would seem that they are working properly.
If your arrows were pointing at something else in the photo that I can't check at the pin connectors, then it would seem that I have to open up the plastic sensor sleeve to get at something inside.  I see a seam in the plastic, but I'm not sure this will come apart without destroying the sensor.
I could use some clarification.
In the meantime, I think I'll put the cluster back together enough so I can run some jumpers from a 12v battery to the cluster pin #6 for power, and a jumper from the red wire prong on the sensor unit to cluster pin #7 (the 4L light), and a jumper from the brown wire pin on the sensor to pin #13 on the cluster for a ground, and see if I find any joy. Maybe all the sensor pins need to be connected somewhere for the light to come on?  If anyone has a better suggestion for a test, please let me know.
Thanks again.
Post by: rbm on June 24, 2015, 12:27:55 PM
If you measured 1200 ohms, you have accomplished two tasks:
1. proved the thermistors are correct at the appropriate temperature
2. identified the two connector pins that correspond to one end of EACH of the thermistors (pins T1 and T2).  Now all you have to do is identify the pin that goes to the common connection (pin 31) aka. ground.
The easiest process at this point is to use an ohmmeter to identify the pin that corresponds with the fuel pump's purple lead (pin 15).  Once you identify that pin, the only remaining pin must be ground.
Don't open the sensor.  I was only annotating your photo to show you that two thermistors exist.  Take my word for it; yours does also.
Post by: rogan on June 24, 2015, 01:58:55 PM
Rbm, OK, that sounds like progress.  So the brown wire inside the sensor I was thinking was the ground is actually one of the thermistors? And the red wire is the other. I guess I still don't know which pin is for the 4L light, and which is for the 7L light, but trial and error should resolve that.  I can see the pin that the purple wire connects to.  That would mean that the ground is the pin fed by the two gray wires.
So excluding the funky connectors and wire colors that someone inserted between the sensor pins and the original (I hope) wire harness, the "original" wire colors heading toward the instrument cluster are: brown, brown/black, brown/white, and green/white or yellow (could be discolored). Looking at the instrument pin cluster arrangement you posted, the 4L wire should be brown/ white at pin 7, the 7L should be brown/black at pin 8 (which I apparently am not going to get to work), and pins 13 and 18 both show as grounds, color brown. The color unaccounted for at the cluster is my green/white (or green/yellow). Could this be 12V power? If so, should it be connected to the sensor pin connected to the purple fuel pump wire?  Looking at your color schematic, it looks like there is a green/white wire that goes to the #6 fuse.
Sorry for all these basic questions, and I appreciate your patience on a problem that no doubt is trivial to most people.  Can't wait till I get to the spline lube job, among other things!
Post by: rbm on June 24, 2015, 03:39:10 PM
Yes, it is 12V power for the fuel pump coming off fuse #6.
Quote from: rogan
Yes, see my answer above.
Post by: rogan on June 24, 2015, 05:10:34 PM
OK, I reconnected the wires using the existing connectors, all of which tested having good continuity back to the multipin connector on the back of the instrument cluster, (and the green/yellow power lead back to the #6 fuse), but matching the original wiring harness colors to the pins coming off the fuel sensor as discussed above. I also swapped the connectors for the two thermistors (the brown and red wires inside the sensor) back and forth, but still didn't get the 4L lamp on the dash to light.
Seems like that should have worked, so I'm still perplexed.  I've already tested the bulb and its socket several times.  I suppose there could be a fault on a circuit inside the cluster at the bottom of all this.
Post by: rbm on June 24, 2015, 07:10:32 PM
Can you confirm that the lamp contacts the metal film on each side of the slot into which the lamp plugs?  The bare metal ends have to stick into the hole and the lamp has to contact them.  A common problem is accidently lifting the flaps when removing the lamp bulb.
Post by: rogan on June 24, 2015, 07:15:56 PM
Yes, I've been careful to check the copper flaps each time I put the bulbs back in, and have cleaned off the socket contacts in case that was the problem.
Post by: rbm on June 24, 2015, 07:43:57 PM
 It might be a defective fuel sender circuit card.  It could be a broken trace on the flexicard in the instrument cluster.  I'm out of ideas for the moment.
Post by: rogan on June 25, 2015, 12:09:06 PM
Yes, those seem like the likeliest possiblities at this point.  I assume that contacts T1  and T1 prime on the PCB relate to the 7L circuit, since those are the ones with no connections present on the blue flexi overlay , and we've concluded that I have an '86 or later overlay;  and contacts T2 and T2 prime are for the 4L circuit.
Since I can't really troubleshoot the PCB or overlay, except for looking for broken connections, I guess (other than living with it) my best option is to look for used parts that aren't too expensive to take a chance on.
I did come across this modification that was posted in 2002, but it seems like this would be more pertinent to a bad sensor problem than to a problem inside the PCB or blue flexi overlay:
"Early K-bike Fuel Light Fix
By Jim Solberg
September 2002
K-Tech Page Maintainer's Note: This will only work for early K-series bikes. Certainly those with the amber 7l light and the red 4l light, later ones up to the point where the analog sender was installed.
Purchase two 1 K OHM potentiometers from Radio Shack, #271-342, for $1.49 each. Splice one into the brown/white (4 liter) wire and the other one into the brown/black (7 liter) wire, where the wires go into the tank.
Measure 4 liters of fuel into an empty tank. Adjust the potentiometer for the red light so it comes on at the 4 liter content in the tank.
Obviously, the other potentiometer should be set so that the yellow light comes on at the 7 liter level. Of course, you could be creative and set them to come on at any level you desire.
Rather than empty the tank, I emptied almost all of it, then ran the bike until it ran out of gas, so I would have a true indication of liters remaining of useable capacity.
You can get as fancy or simple as you want with the installation. I mounted the pots in a small plastic box, with the adjustment screws accessible through two small holes drilled in the box. I also mounted a small switch through the box and wired it to be able to disconnect everything from the fuel lights just in case the fix didn't work. I spliced in enough wire to be able to mount the box to a frame member just behind the right side cover. I filled the box with silicone, completely covering the pots and switch, as protection from the elements and vibration.
This fix has worked flawlessly for sixteen years."
Or do you think this would be a workaround for my problem?
Another possibility that occurred to me: people have said that the fuel lights won't come on in "test" mode with the ignition switch on but the bike not running, and fuel in the tank.  But I'm assuming that the 4L light should come on when the sensor is hanging out of the empty tank with the ignition on, even though the bike obviously is not running.
Don't know if anyone can confirm this on a working bike: when the fuel is low and you turn the ignition on (position 2), does the low fuel lamp come on before you start the bike?
Thanks.
Post by: rbm on June 25, 2015, 06:15:20 PM
The workaround will probably not fix your problem.
The 4L light should work whether the engine is running or not, but the ignition switch has to be ON (i.e. not in the park or OFF  positions). Someone who owns a pre-86 bike should be able to confirm this.
Hooking up the sender and powering up the instrument cluster should cause the light to come on.  It's exactly like the sender was inside the tank and the fuel level dropped below 4L.
Post by: rogan on June 25, 2015, 07:40:05 PM
Agreed. Thanks.
Post by: rogan on June 27, 2015, 11:44:33 AM
Hello all,
I want to thank everyone who took the time to help me with this problem, especially Inge, and most especially Rbm.  I learned a lot during the process, even though I still haven't solved the problem.
 I'll probably try to disassemble the circuit boards a bit more at some point in the future to see if I can find any broken connections on the back side, since it seems like we've narrowed down the likely causes to a fault either in the fuel warning pcb or the blue plastic flexi overlay.  If someone has a test for the pcb board itself that could narrow the possibilities further, that would be great.
In the meantime, I've posted a request on the parts forum in case anyone has a fuel warning pcb or blue plastic overlay assembly for a 1985 K100 RS, or a little later one that is compatible.  My speedo, tach, and most of the other instruments are working fine(or at least were before I started taking everything apart!) so I don't really need a whole cluster, but if anyone has working spares, or even these components that are questionable, but the price is low enough for me to try to make work, please let me know.
Thanks again for everyone's help, and I'll let you know if I come up with anything new.
Cheers.
Post by: rogan on July 14, 2015, 06:20:02 PM
Just thought I'd post an update.  I took apart and reassembled the cluster a couple more times, and after the last time, I was able to get the 4L lamp to light up with the gas tank drained and the sensor hanging out.  Don't know what changed or if it will stay working after I finish cleaning out the tank and pump screen, replacing the fuel filter, and reinstalling the fuel pump (which I'm having some trouble doing, and have posted for some advice).
Anyway, it's progress at least, and I'll keep my fingers crossed that once I get everything back together that the 4L lamp will still be working.
Thanks again to everyone.
Post by: petermarek on July 26, 2015, 10:05:02 PM
Folks. I have just finished re-furbishing a 1985 K100 RT. BEFORE I tore the bike down and built it back up (it sat for ~15 years under a car port) the Clock worked....Now it doesn't. Everything else does work although the Gear indicator LCD is "bleeding" now. I suspect 15 years of freezing/thawing caused that.
Also the left turn signal has just started intermittently working. The right signal works reliably.
Any sage advice on the Clock and the turn signal?  Is the turn signal relay partitioned for left and right? Can only 1 signal go bad?
The clock would be just nice to have....
Thanks in advance!  :bmwsmile
Post by: rbm on July 27, 2015, 02:36:50 AM
Inside the relay, there is a complex electronic circuit; it's not a simple relay.  If the left signal is intermittent, the cause is a dirty left switch cluster.  Your symptoms are probably that the signal is hard to get going but cancels promptly.There are threads on how to disassemble and clean the switch cluster. Or read this PDF writeup (http://technik.flyingbrick.de/images/f/f9/61_lenker_rechts.pdf).  Be very careful not to loose the tiny springs inside.
Post by: petermarek on July 27, 2015, 09:25:40 AM
You are correct, Once the signal does start working, the cancel (manual and auto) works fine.
I'll start the dis-assembly and have the dielectric grease handy.
Your advice also makes sense as during the breakdown/rebuild process I came across small (dead) mud wasp nests throughout the bike. That's in addition to the mouse nest on top of the block beneath the Air filter.
Now I just need to learn German to fully understand the PDF...but the pictures help!  :2thumbup:
Thanks
Post by: 84K100RT on December 17, 2015, 06:06:24 PM
Just enquiring as to how the cluster replacement worked out.
I have an 84K100RT and am aware of the different clusters as they changed during 1985 [old ones have bolt down gas tank and seat handles in the seat] along with a lot of other changes like fuel tank electrical connections. I got one locally that is same year and has the 4/7l warning lights. I have an issue with the speedo and while I know it can be repaired I don't want to be off road as the Ks don't run without the cluster in place.
The 'new' one is in great condition but I am curious as to how difficult is it to fit?
