TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: scotlandkane on May 25, 2015, 11:45:10 PM
Hey folks...
So my 1995 K75 seemed to be running smoothly until it decided to quit on me and left me on the side of the road. At first I thought it had run out of gas, but there was plenty in the tank. When I tried to start it up it would turn over but not fire up.
Should I try to replace the fuel filter first?
Suggestions?
Thanks!
Grace
Fuel filter and whilst your in there look for any bits of rubber, use a torch not a match to light up the area though, how many miles has your K?
ssray it has 67,000 miles on it
Do you hear the fuel pump running when you press the starter switch?
Check the 4pin connector at the right rear of the fuel tank. Not uncommon for bad/dirty electrical connection here and cause fuel pump to stop.
