TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: beemuker on May 05, 2015, 10:50:34 AM
Title: Throttle cable adjustment?
Post by: beemuker on May 05, 2015, 10:50:34 AM
I have some play in my throttle and I've searched and found no mention of how to adjust it, if possible. I see the adjuster for the "choke", but can't locate one for the throttle cable. maybe I should follow " if it works, don't fix it"?
Title: Re: Throttle cable adjustment?
Post by: TX brick on May 05, 2015, 02:15:51 PM
My 91 has a boot on the cable where it exits the throttle housing. Under that boot is an adjuster.
Post by: beemuker on May 05, 2015, 02:54:27 PM
thanks, I'll look
Post by: TaosBrick on May 06, 2015, 09:17:05 AM
There is also another adjuster at the throttle body end of the cable.
Post by: beemuker on May 06, 2015, 10:52:50 AM
is that easy to get to, i dont see it
Post by: TimTyler on May 06, 2015, 11:23:33 AM
Mine doesn't have a cable adjuster on the throttle body end, just a throttle body idle adjustment screw that I think we're not supposed to adjust.
The cable should be adjusted up at the handlebar end.
Post by: beemuker on May 06, 2015, 12:04:32 PM
thanks, looks easy enough
Post by: zenitramnaes on August 14, 2018, 06:58:43 PM
Where can I find an adjuster? The bike I just bought was using a Bilwell throttle and had removed the stock levers. I put them back on but I'm missing this adjustment option.
Post by: johnny on August 14, 2018, 07:35:45 PM
greetings..
i may have one... whats the part number...
Post by: zenitramnaes on August 14, 2018, 07:37:43 PM
Not sure, having a hard time finding this one on realoem.
Post by: johnny on August 14, 2018, 07:43:23 PM
it maybe part of the oe bowden cable...
Post by: zenitramnaes on August 14, 2018, 07:47:48 PM
All of the cables I'm seeing for sale on different sites don't have the adjuster. That and not seeing it on realoem led me to believe that it's a separate part or maybe the updated version of the cable but I'm not sure.
