TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Thorfinn on May 02, 2015, 07:06:07 AM
Title: Are these kill switches a known problem?
Post by: Thorfinn on May 02, 2015, 07:06:07 AM
My K75 has been sitting in the garage over winter (yeah I know, but I live in Cornwall..!)  :euro and started and ran fine when I took it for its MOT test last week. Now, not so good. Totally dead. I know the battery is fully charged.
I'm suspecting the kill switch - wondered if it was a known issue on K-Bikes? It was in the "Off" position throughout the bike's hibernation.
Thanks for any ideas,
Thorfie
Title: Re: Are these kill switches a known problem?
Post by: Inge K. on May 02, 2015, 07:16:28 AM
Have a look at last picture on page two. (http://technik.flyingbrick.de/images/f/f9/61_lenker_rechts.pdf)
...if your horn or headlight doesn't function, check the ignition switch instead.
Post by: Thorfinn on May 02, 2015, 08:59:00 AM
Thanks Inge. I was hoping it wasn't the Ignition switch - I rebuilt it just last year! Mind you, we must remember the old saying:
"If it ain't broke, I ain't worked on it yet" :oops:
So it could be me being as cack-handed as ever. Just one thing: Doesn't the killswitch disable things like lights and horn too?
Post by: Inge K. on May 02, 2015, 09:32:19 AM
No.......after the ignition switch the circuit split in two, one wire to the kill switch...
the other to the load shedding relay (lights, horn ++).
Post by: motodude on May 02, 2015, 05:53:16 PM
You may want to disassemble the switchgear and clean the contacts.  Just be careful that you don't lose any screws.  After removing from the handlebar, put in a shoe box or similar to catch them.
Tom
Title: Re: Are these kill switches a known problem? - SOLVED!!
Post by: Thorfinn on May 21, 2015, 12:05:43 PM
Thanks to all for advice on this. The killswitch and the ignition switch were fine in the end...BUT the connector under the tank for the ignition switch was intermittent. I cut it out and got soldering - seems to have done the trick!  :riding:
Cheers
Thorfie
