TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 3DdesignsK75S on April 25, 2015, 09:21:47 PM
Looking for a set of handlebar grips for my 91 75s. Looks like it might be a 1" diameter that fits.(?)
Can somebody confirm the size and maybe some sources to get them from?
I am just looking for standard non heated grips.
Also need a front right footpeg.
Thanks in advance.
oem bars are 22mm eruo and nearly equivalent to 7/8" usa...
i would put some heaters on there with a heattoller... will come in handy on sunrise highway and banner grade...
Left grip would fit 22mm diameter but the right would fit 25mm to account for the larger diameter of the throttle tube. It would be possible to substitute aftermarket 7/8" grips instead of OEM BMW ones, as Johnny has previously pointed out.
OK, so do I need to get two sets? 1- 7/8" (22 mm) and one 1" (25 mm)?
generally... a pair of grips... lets say for 22mm bars... one grip will be slightly larger in dia for the throttle side... should say in their documentation... doo your doo dillergence...
Great. Thanks again.
