TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: 3DdesignsK75S on April 21, 2015, 03:40:08 AM
Title: Sticking K75s light switch
Post by: 3DdesignsK75S on April 21, 2015, 03:40:08 AM
Is there a way to clean, lube etc. to get the left hand side high beam low beam switch working? Any btdt?
Title: Re: Sticking K75s light switch
Post by: Motorhobo on April 21, 2015, 06:37:03 AM
+1 good question - I have a switch that sometimes blacks out the lights. Toggling it a couple times gets it back working, but compared to the other K75 this switch is definitely in need of service. This bike was a zombie for three years which probably didn't help the switches.
I found this:
http://www.motobrick.com/index.php/topic,5961.msg39019.html#msg39019
http://www.motobrick.com/index.php/topic,6299.msg42238.html#msg42238
If you don't have e headlight relay mentioned in the second link, it comes recommended -- I put it in last year and really improved the headlight performance, and probably prevented further damage to the switch.
Post by: 3DdesignsK75S on April 21, 2015, 01:30:30 PM
Thanks for the links. I'll investigate further to see what is up with mine exactly.
Post by: rbm on April 21, 2015, 08:36:12 PM
http://technik.flyingbrick.de/images/f/f9/61_lenker_rechts.pdf
Use Google to translate.
Post by: 3DdesignsK75S on April 22, 2015, 02:53:44 AM
Sehr gut! Vielen Dank.
