TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: Scott_ on April 14, 2015, 10:44:17 PM
Ok, so here's what happened today. Coming home from work, got out on the 4-lane and I wanted to wind-er-up.
I stayed in 4th to keep the speed down obviously, don't need any performance awards....
The motor was singing right along easily 6K-7k, I went to back off the throttle, and no reduction. I tried to snap the throttle a couple of times to get it to back off, didn't work right away. I touched the brakes a bit to load it down some, to down-shift, not a good idea........
As soon as I touched the clutch I realized I did an oooops. I let go of it right away, but not before the motor went little-no load speed. I did finally get the throttle to release, but the result was I now had an obvious mis-fire.
It got me home with 3cyl.
I located the cause of the sticking throttle cable and corrected it. A piece of my fuel line insulation became unfastened from the fuel line and was in the perfect position to catch/snag the cruise control linkage. No longer..
Back to the misfire, 1st I connected my carbtune to see if I could tell which cyl I was dealing with, didn't tell me anything. All 4 still showed decent vac, so that was a good sign anyway.
Pulled the plugs, got the 1st 3 out and they still looked like new, pulled the 4th and low and behold there was no gap. Bosch XR5DC
Near as I can tell the top of the piston came up and hit the plug. Got my light out and I couldn't see any damage thru the plug hole, ran a compression test, came back good 185+.
So I re-gapped the plug, put it all back together, and it fired right up as if nothing was wrong. Took it out on the highway again, ran it up to 7K+, no problems. So I'm not sure if it was just a fluke that the piston tapped the plug, or if it's a sign of excess piston travel to be concerned with, or possibly just a layer of carbon buildup on the top of the piston.
Thoughts?
Oh, btw this was the '97 with 49K miles.
Interesting story...I can't offer anything but maybe Lady Luck threw you a break. It seems weird that a mechanical device could stretch and then return to it's original length (the rod) but who knows. Glad to hear it's running properly. Don't do that again!!
