TECHNICAL MOTOBRICK WRENCHING In Remembrance of Inge K. => The Motobrick Workshop => Topic started by: KCinSB on April 05, 2015, 10:26:50 AM
Title: K1100, no turn signal cancel
Post by: KCinSB on April 05, 2015, 10:26:50 AM
Sorry if this has been handled before.
My '93 K1100 turn signal cancel button has stopped working. I took the switch assembly apart, and cleaned all the contacts on all switches in there while inside. They were ugly, and I thought that would surely be the fix. Nope, still no cancel.  Is there a common issue I should look for next?  They do self cancel with riding distance, but that isn't good around town.  I seem to recall there is a holding relay involved...?
Title: Re: K1100, no turn signal cancel
Post by: rbm on April 05, 2015, 10:56:11 AM
Have you tried reseating the RH cluster multiplug connector under the tank?  There might be poor contact there.
Post by: KCinSB on April 05, 2015, 02:23:03 PM
No, I have not tried that.  I want to find out which plug contacts are from the cancel switch, and prove the signal is coming from the switch as it should.  what it does is still a mystery after that.
Post by: KCinSB on April 05, 2015, 05:09:19 PM
Decided to check if the switch contact was "making", and even though I had cleaned the momentary contact previously, it was not showing continuity through the switch.  Took the switch assembly apart again, and decided the issue must be the Pivot contact in the switch. This is a contact Bar situation, where the bar makes contact with 2 points to make the circuit. The bar sort of rotates about the 1 contact and touches the 2nd momentary contact. That 2nd contact was fairly easy to clean, and I had done that. Never though about the other end of the bar, that is in constant contact with the 1st point. I was able to retract the spring loaded bar enough to get a blade into the 1st contact area, and scrape it clean. Switch together, signals cancel. So it WAS the switch all the time. Related this process if it helps anyone else with a no cancel problem.
